Understanding Conventional Current and the Right Hand Rule for B-Field Direction
  • Thread starter Thread starter learning_phys
    Current
The discussion clarifies the conventions of current flow and the application of the right-hand rule for determining the direction of the magnetic field (B-field). It establishes that conventional current flows from negative to positive, while voltage is a fixed quantity that does not flow. The right-hand rule is used to ascertain the B-field direction based on the established current flow convention. This understanding is crucial for accurately interpreting electromagnetic principles in circuit analysis.
  • Understanding of conventional current flow
  • Familiarity with the right-hand rule in electromagnetism
  • Basic knowledge of voltage and its role in circuits
  • Concept of time-invariant circuits
  • Study the application of the right-hand rule in various electromagnetic scenarios
  • Explore the differences between conventional current and electron flow
  • Investigate time-invariant circuit analysis techniques
  • Learn about the implications of voltage in circuit design and analysis
Students and professionals in electrical engineering, physics educators, and anyone seeking to deepen their understanding of electromagnetic theory and circuit analysis.
learning_phys
My text shows current flowing from negative to positive, and also uses the right hand rule to get the B-field this way. I always thought convention was to flow from positive to negative, and also the b-field followed this convention as well. Any comments?
As I recall, the convention is that current will flow from negative to positive while potential (voltage) will flow from positive from negative.
Current always flows from positive to negative voltage, unless it's within a voltage source. And voltage (or potential) doesn't "flow" at all. It's a fixed quantity in time-invariant circuits.
