Inverse Laplace Transform Control Systems
The discussion revolves around the challenges of performing the Inverse Laplace Transform in the context of control systems. Participants share their experiences and methods related to the mathematical techniques involved, particularly in situations where standard tables may not suffice. The conversation touches on theoretical and practical aspects of the Laplace Transform and its applications in engineering.
  • One participant expresses concern about the feasibility of performing an Inverse Laplace Transform without relying on standard tables, mentioning difficulties with substitutions and integration methods.
  • Another participant suggests that performing an inverse Laplace transform directly is challenging and mentions the use of a disturbance function to handle non-linearities in control systems.
  • A different participant describes a method involving contour integration in the complex plane, noting that certain parts of the contour can yield zero, which aids in evaluating the integral.
  • One contributor emphasizes the importance of choosing the correct contour for complex integrals and references Cauchy's integral theorem and the residue theorem.
  • Another participant points out that while it is possible to calculate the inverse transform manually, it is often impractical, and tables are typically used for efficiency.
  • One participant recalls a resource that explains contour integration as a method for the inverse transform, highlighting the utility of tables and rules of thumb in solving practical problems.
  • A later reply raises a question about the conditions under which contours must include poles, expressing confusion over differing statements regarding contour requirements.
Participants do not reach a consensus on the necessity of including poles in the contour for the inverse Laplace transform, with some suggesting it is essential while others indicate it may not be required. The discussion remains unresolved regarding the best approach to performing the inverse transform without tables.
There are limitations in the discussion regarding the assumptions made about the stability domain and the convergence of the Laplace Transform, which are not fully explored. The scope of the discussion is primarily focused on theoretical methods rather than practical applications.
Adder_Noir
Hi I am currently working my way through a control systems textbook and I am bringing my understanding of the relevant mathematics up to speed. I have happened across the Laplace Transform which I am happy enough with. I am concerned however that given the fact that this is a real project I may find that the present calculations in the machine's software I am working on may not fit into something that can be easily inverse transformed using the standard models in the tables. Maybe I am worrying unnecessarily but I would like to be able to perform a complete Inverse Laplace Transform without the use of the tables. I am a competent mathematician, but using conventional methods I have not been able to perform this transform. Is it possible to do this, or this beyond the scope of anyone without a degree solely in mathematics? I have tried all sorts of substitutions and integration methods and so on, but I keep ending up with equations which cannot be manipulated any further, or just keep growing into even nastier equations. Can anyone give me a clue as to how this is actually done without the aid of tables or a computer? :smile:
I hope this has made some sense!
Hi Adder,
Welcome to the forums!
Doing inverse Laplaces is not an easy proposition. IIRC, you need to do a integration over a surface in state space.
FWIW, I've yet to see a problem which requires a direct inverse laplace to be performed.
Non-linearities are usually wrapped up into a 'D' disturbance function. This disturbance function contributes to steady state error, and extra poles at the origin of the controllers are added into counter them.
I have seen a Laplace transform inverted by setting up a "trick" contour and doing contour integration in the complex plane (no poles inside the contour). The LT turns out to be identically zero on part of the contour and hence the whole contour integral, which can be evaluated, equals the negative of its value on the other part, which was sought. Actually the zero part of the contour is the mirror image of the non-zero part in the imaginary axis, and the zero comes from the positivity of the LT.
Wow! I wasn't expecting advice as good as and as helpful as that. Thankyou both very much. The trick contour idea seems fascinating. I suspect that may well be a bit out of my depth at present, but what a great idea! It's also a big relief to hear that it is unlikely I will have to perform an inverse LT for this project. I have to say however it is something out of shear curiosity I would love to be able to do one day.
The D(s) function was something I have not been introduced to before, but makes an awful lot of sense. Thankyou very much for that. Once I have some more data about the machine (likely this week) I will get back to you again.
Thanks for the advice! :wink: :smile:
Exellent Self adjoint
The idea to use the contour complxe is exellent and u must pay attention how choose the contour
Then u have a complexe integral (or Cauchy's integral) and use Cauchy's integral theorem or The residue theorem.
Really i felicite THe Self adjoint "Operator"
When you learn to integrate, you use tables that you learn to do hard integrals... obviously you can calculate it yourself, but is a very hard work...
With Laplace occurs the same, you are condemned to use tables xD
I seem to recall that the Schuam's Outline Series on the Laplace Transform gives a good explanation of the contour integral as the inverse transform.
One of the main reasons people use the Laplace Transform is that the tables and a few rules of thumb can be used to solve almost any real problem.
From what I remember, the contour must contain all of the poles. But from what selfadjoint has said, it can contain none of them? I am lost. When you do a Laplace transform, you should be implicitly aware of the domain of stability, which basically limits you to a region of the frequency domain to the left of some line. Then, you have to make sure to include this entire region inside your contour when you take the inverse Laplace transform. Look closely at the tables and you should see restrictions on the real part of s. For example, IIRC:
L{u(t)} = 1/s, where Re{s} > 0
This is directly related to the convergence of the kernel of the transform: e-st. If Re{s} < 0, then this kernel will "blow up" as the integral is taken to t -> infinity.
