How Can I Accurately Measure Voltage Drop across a Capacitor?
The discussion focuses on accurately measuring voltage drop across a capacitor during a leakage current test. A simple subtraction of initial voltage from the final voltage is insufficient due to the exponential decay characteristic of capacitors. Instead, the voltage can be modeled using the equation V_t = V_{ref} * e^{-t/(RC)}, where V_t is the voltage after time t, V_ref is the reference voltage, R is the resistance, and C is the capacitance. This approach allows for precise calculations of the parallel resistance affecting leakage.
  • Understanding of capacitor behavior and exponential decay
  • Familiarity with the formula V_t = V_{ref} * e^{-t/(RC)}
  • Knowledge of measuring voltage and time in electrical circuits
  • Basic concepts of leakage current and parallel resistance
  • Research methods for measuring capacitor leakage current accurately
  • Learn about the effects of parallel resistance on capacitor discharge
  • Explore advanced capacitor modeling techniques using circuit simulation tools
  • Study the implications of time constant (RC) in capacitor circuits
Electrical engineers, circuit designers, and technicians involved in testing and measuring capacitor performance and leakage characteristics.
simoncastle
Hi all,
Here's the problem!
I am attempting to create a leakage current test suite. Basically it centers around cutting the voltage reference supply to a capacitor and measuring the voltage drop. Similar to the one in the attachment.
I figured that to determine the drop it would be a simple case of V at start minus V after time delay.
However a colleage told me that because of the exponential decay of capacitors this simple equation wouldn't be enough to accuratly determine the voltage drop.
Any ideas?
Thanks!
- Si
I'm assuming you want to measure the parallel resistance (which causes the charge to leak) of the capacitor.
You can use an exponentially decaying function for the voltage:
[tex] V_t = V_{ref} \ e^{-t/(RC)}[/tex]
where Vt is the voltage after t seconds. Solve the equation for R after measuring all other quantities (Vt, Vref, t, and C)
  • · Replies 18 ·
9K
9K
