Checking & Removing Water from Methanol Gas Dryer in Wichita KS
  • Thread starter Thread starter moe7404
    Methanol Water
This discussion focuses on checking and removing water from methanol gas dryers in Wichita, KS. Users suggest that high water content in methanol (MeOH) can weaken vehicle performance. To check for water, one can dip filter paper into the methanol to observe evaporation rates, as MeOH evaporates faster than water. For removal, utilizing specific adsorbers is recommended, and the most reliable method is to analyze samples and report findings to the gas station.
  • Understanding of methanol (MeOH) properties
  • Knowledge of gas dryer systems
  • Familiarity with evaporation testing methods
  • Experience with adsorptive materials for moisture removal
  • Research methods for analyzing methanol samples
  • Learn about different types of adsorbers for moisture removal
  • Investigate the impact of water content on engine performance
  • Explore best practices for maintaining gas dryer systems
This discussion is beneficial for automotive technicians, gas station operators, and anyone involved in the maintenance and performance optimization of methanol gas systems.
moe7404
moe in wichita ks
if i buy a "gas dryer" methanol. how can i check to see if it has water in it?
and if it has water can it be removed?
- You can feel your car weaker if running on high water content gas (MeOH)
- I have not checked, but MeOH evaporates much better than H2O. You can dip a filter paper into the gas and see how fast it evaporates
- One way to remove H2O out of MeOH is to use some kinds of adsorbers
* The best way is to bring samples for analysis and then fine the gas station
  • · Replies 160 ·
11K
