Thread Closed
lenses question
Share Thread Thread Tools
Aug3-08, 03:10 PM   #1
lenses question
An object is 18cm in front of a diverging lens that has a focal length of -12cm. How far in front of the lens should the object be placed so that the size of its image is reduced by a factor of 2.0?
2. Relevant equations
1/do + 1/di = 1/f
m= -di/do
3. The attempt at a solution
i keep solving and getting 36 using those equations, but the answer says its 48 ...i donno how to get 48
1/18 + 1/di = 1/-12
di=7.2
m= -7.2/18
m=-.4
1/2m=-0.2
-.2= -7.2/do
do=36
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Aug3-08, 03:16 PM   #2
G01
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Can you show your calculations, please? I can't find your mistake if I can't see your work.
Aug3-08, 03:19 PM   #3
k i edited it
Aug3-08, 03:30 PM   #4
G01
Recognitions:
lenses question
Hmmm. I am also getting 36 as my answer. I know this is a stupid question, but are you sure your numbers are correct? It doesn't hurt to check. Also where are you getting the answer from?
Aug3-08, 03:38 PM   #5
physics textbook
Aug3-08, 08:58 PM   #6
bump
Aug4-08, 06:46 AM   #7
Recognitions:
Quote by physicsdawg View Post
Hi physicsdawg!
Try using 8cm instead of 18cm.
Aug4-08, 11:06 PM   #8
Recognitions:
Hi physicsdawg,
1/do + 1/di = 1/f
m= -di/do
1/18 + 1/di = 1/-12
di=7.2
I believe this answer is incorrect. The numerical value is right, but it needs to be a negative number.
m= -7.2/18
m=-.4
1/2m=-0.2
With di=-7.2, all of these magnifications will be positive numbers (which checks out, since a single diverging lens creates upright images).
-.2= -7.2/do
The second image will not be in the same place as the first image, and so the di for the second case is an unknown quantity. This equation should therefore be:
[tex]
0.2 = - di/do
[/tex]
and you need to find do. Do you see how to find it?
Aug4-08, 11:21 PM   #9
G01
Recognitions:
Quote by alphysicist View Post
Hi physicsdawg,
[tex]
0.2 = - di/do
[/tex]
Ahh, of course. The second image is not in the same place as the first. I made that mistake as well. ( For some reason, I thought that was a condition in the problem. Guess I read into it too much.) Nice catch alphysicist.
Thread Closed
Thread Tools
Similar Threads for: lenses question
Thread Forum Replies
Lenses Question Introductory Physics Homework 0
Lenses Question help! Introductory Physics Homework 2
Quick Question about lenses/refraction Introductory Physics Homework 1
question about sound and lenses General Physics 0
Question about Convex lenses General Physics 6
