Calculating Power and Torque for Rotational Motion
  • Thread starter Thread starter Cyannaca
    Torque
The discussion revolves around calculating the power required to maintain a grinding stone's rotation at a constant angular velocity, given its radius, moment of inertia, rotational speed, and applied force. The subject area includes concepts of rotational motion, torque, and power in physics.
  • Participants discuss the relationship between torque and power, with some suggesting the need to convert rotational speed from RPM to rad/s. Others mention the role of friction and the work-energy principle in determining the power required.
Some participants have provided insights into the relationship between the work done by the motor and the work done by friction, noting that the power of the motor should equal the power removed by friction. There is a mix of attempts to clarify the calculations involved, but no consensus has been reached on a specific method or final answer.
Participants are working under the constraints of an exam preparation scenario, with a specific answer expected. There is mention of a kinetic coefficient of friction and the need to maintain constant angular velocity, which may influence the calculations discussed.
Cyannaca
I would really appreciate if anyone could help me with this problem. My exam is in 3 days and I don't understand how to do this problem!
A grinding stone of radius 10 cm ( I=0,2 kg*m^2) turns at a rate of 200 RPM. A tool is leaned against the circumference of the grinding stone with a force of 50N of radial direction. The kinetic coefficient of friction is equal to 0,6.
(A) What power is necessary to maintain the grinding stone in rotation at a constant angular velocity?
The answer is supposed to be 62,8 W and I know I have to use torque but I really don't know how to do it :confused:
power formula: (T is torque, t is time)
[tex]P = \frac{T \theta}{t}[/tex]
[tex]P = T\omega[/tex]
convert 200rpm into rad/s and it should be easy from there.
I just worked the problem all the way through and the answer does work out.
There's a real easy way to do this - almost a short cut.
Notice that if the stone must be turning at a constant angular velocity, it's Kinetic Energy must be constant. So the work done by the motor = work done by friction. Dividing by time, we have the power of motor = power removed by friction.
Also we know that power = force * velocity.
The relevant velocity here is the speed of the edge of the grinding wheel (where the friction acts) = w*R, where w is in rad/s. Lastly, the frictional force is 0.6 * 50 N = 30 N.
Plugging in numbers, you'll find that P = 63 W
You totally stole that from my post :-p
Shawn how did he steal that from your post?
  • · Replies 35 ·
15K
