Proving Rectangles with Area/Perimeter: Square is Best
  • Thread starter Thread starter illjazz
    Square
The discussion revolves around proving properties of rectangles related to area and perimeter, specifically that a square has the smallest perimeter for a given area and the largest area for a given perimeter.
  • Participants discuss the relationships between the sides of rectangles, their area, and perimeter, with some attempting to express these in mathematical terms. Questions arise about how to start solving the problem and the implications of fixed area and perimeter.
There is an ongoing exploration of the problem, with participants suggesting breaking down the question into simpler parts and using examples. Some guidance has been offered regarding expressing perimeter in terms of one variable and considering calculus for optimization.
Participants express confusion about the problem setup and the implications of fixed area and perimeter. There is mention of using calculus to find minimum or maximum values, as well as alternative methods for those who may not prefer calculus.
illjazz
a) Show that of all the rectangles with a given area, the one with smallest perimeter is a square.
b) Show that of all the rectangles with a given perimeter, the one with greatest area is a square.
- Differentiation rules
- Superhuman powers
I'm completely lost on this one. I honestly don't even know where to start. Of all the rectangles with a given area? What?
So let's introduce some variables.
Say we have 3 rectangles. Their areas are a1, a2, a3. Then their perimeters are p1, p2, p3. Now if p2 > p1 <p3, i.e. p1 is the smallest of the three perimeters, then the rectangle 1, with area a1 and perimeter p1 is square. I get the question.. but I still don't have a clue about where or how to start.
Since b) is very similar, the same goes for b).
Can you break the question down for yourself by using examples? You can have very skinny rectangles with lots of perimeter and little area, for example. This problem also extends to other 2-d shapes. What is the largest area that can be encompassed by a 2-d shape? How is this shape approximated in regular 2-d shapes?
Hi illjazz! :smile:
Let's do it step by step …
If a rectangle has sides x and y:
i] what is the area, A?
ii] what is the perimeter, P?
Now if A is given (fixed), what is the smallest value of P (in terms of x and y)? :smile:
The largest area that can be encompassed by a 2d shape? Um.. I'd say infinity. A shape is approximated by taking a 2d object with n "sides" and then increasing the number of sides long enough to reach the desired level of precision, I guess?
tiny-tim said:
Hi illjazz! :smile:
Ok. So we have the sides, x and y. Then the area A is
i] A = xy
and the perimeter is
ii] P = 2x + 2y
I guess the smallest value of P then would be either 4x or 4y. Huh! This makes sense :). But I just "described" it.. I didn't make any equations :/
i] A = xy
ii] P = 2x + 2y
Well then next you should express P in terms of either x or y only, then optimise the area using calculus. Then you'll get the answer.
Hi illjazz! :smile:
erm … no, it doesn't … it doesn't tell you anything at all!
The problem is:
Given xy = A (a constant), for what value of x (in terms of A) is 2x + 2y smallest? :smile:
Yes, that is the question. Also, since you know that xy= A, y= A/x where A is some constant. That let's you replace the "y" in P= 2x+ 2y so that the perimeter, P(x), is a function of x only. Now, the crucial question: do you know how to use calculus to find where a function takes on a maximum or minimum value?
