Convex mirror, and you point a light at it horizontally
When light is directed horizontally at a convex mirror, it reflects in such a way that it appears to originate from the focal point, provided the mirror's aperture is small relative to its radius of curvature. This principle holds true in the limiting case of small mirrors. However, when using a hemispherical mirror, the larger size compared to the radius of curvature alters the reflection behavior, leading to glancing reflections that do not conform to the standard focal point rule.
  • Understanding of convex mirror properties
  • Knowledge of focal points in optics
  • Familiarity with the concept of radius of curvature
  • Basic principles of light reflection
  • Research the principles of light reflection in concave and convex mirrors
  • Study the effects of aperture size on mirror reflection behavior
  • Explore the mathematical derivation of focal points in optics
  • Learn about the applications of convex mirrors in real-world scenarios
Students of physics, optical engineers, and anyone interested in the principles of light behavior and mirror optics.
Alkatran
If you have a convex mirror, and you point a light at it horizontally, does the light always reflect through the focal point? (the point halfway on the line connecting border and the center, parallel to the light's initial path)
I remember learning this, but I think of a mirror in the shape of a semi-circle, and you point the light at the bottom, it only bounces along the edge...?
Science news on Phys.org
Horizontal (parallel to the axis) rays will reflect from a convex mirror so that they appear to originate from the focal point.
Also, this is only true in the limiting case when the size of the mirror (aperture) is small compared to the radius of curvature. So, when you take a semi-circular (actually hemispherical) mirror, it is no longer small compared to R. So, the behavior will be different, and hence glancing is not a violation. It's just outside the domain that the above rule applies to.
  • · Replies 18 ·
  • · Replies 22 ·
9K
9K
  • · Replies 51 ·
