Alternating Series: Evaluate E(n = 1) to Infinity
The discussion revolves around evaluating the alternating series E(n = 1) to infinity for the expression ((-1)^(n+1))/n^6. Participants are exploring the requirements for the series to be in a proper form for evaluation.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are questioning the necessity of expressing the series in a "proper form" and discussing the implications of the exponent on the terms. There are attempts to clarify the conditions for the alternating series test and considerations for absolute convergence.
The discussion is active, with various perspectives on the need for a specific form of the series. Some participants suggest that the alternating nature of the series is sufficient, while others emphasize the importance of meeting the criteria for convergence tests. There is no explicit consensus on the necessity of the "proper form."
There are mentions of specific conditions required for the alternating series test and the absolute convergence test, indicating that participants are navigating through the definitions and requirements of convergence in the context of alternating series.
vigintitres
E(n = 1) to infinity ((-1)^n+1)/n^6
This needs to be in the proper form with the exponent on an being n - 1 not n + 1
I don't know how to get the problem into the proper for to evaluate it as an alternating series
I don't know what you mean by "standard form". If you're just trying to prove that the sum converges, the alternating series test requires that you show
(1) [tex]a_n[/tex] is strictly alternating (i.e. [tex]a_{n+1}=-a_n[/tex])
(2) [tex]\lim_{n \to \infty} a_n = 0[/tex]
(3) [tex]|a_{n+1}| \leq |a_n|[/tex]
EDIT: You could also use direct comparison to show that the sum is absolutely convergent.
I don't see why you need a "proper form". I mean it is alternating signs after all. If you wanted the exponent to be n-1 you could just replace n+1 with n-1 since you're just dividing by (-1)^2 = 1. But there really is no point in doing that.
Use the absolute convergence test first when dealing with alternating series. You'll see that in some cases such as this one, using it determines convergence/divergence easily.
But if you really must have "proper form", (-1)n+1= (-1)n-1+ 2= (-1)n+1(-1)2= (-1)n-1 because (-1)2= 1.
10K
