| Thread Closed |
Gauss's law doesnt work here? |
Share Thread | Thread Tools |
| Aug6-08, 06:27 AM | #1 |
So I was doing this one problem in which there is a sphere of radius r and charge density row and there is a spherical cavity inside it whose center is at a distance r2 from the center of the bigger sphere.
Now the question was what is the E field inside the cavity. My first and long thought was that there is no charge inside this cavity, so I will draw a gaussian surface inside this cavity and notice that flux is 0 and say E is 0. After getting the wrong answer, and discussing with some friends , they said to consider superposition of a sphere of charge density -row and then find E and I got the right answer but then why does Gauss law fail in giving me the right result? This might be very elementary but I have just started. |
| Aug6-08, 07:31 AM | #2 |
Mentor
| Aug20-08, 02:42 AM | #3 |
how do you derive equation of E on this question?
i was thinkin of using superposition E=Ebigsphere-Elittlesphere but as the cavity has no charge, then Elittlesphere would be zero which result in E=Ebigsphere. how to solve this? im completely lost!! thanks |
| Aug20-08, 02:53 AM | #4 |
Recognitions:
That's curious. Is Gauss's law really giving you the wrong answer?
| Aug20-08, 04:41 AM | #5 |
| Aug20-08, 05:03 AM | #6 |
Recognitions:
Yes, I'm puzzled too as to why the E-field in the cavity is non-zero.
Now consider any point in the cavity (denote this by A) where we assume the potential difference with the cavity surface is non-zero. A closed equipotential surface, which A lies on, could be drawn within the cavity. Now consider a Gaussian surface which encloses this equipotential surface, but which itself is enclosed by the cavity. If the E-field in the cavity is non-zero, then we should expect the total outward (or inward) electric flux (from the inside equipotential surface to the cavity surface or in the opposite direction) through this surface to be non-zero, which by Gauss law implies that there is a charge in the cavity, which is certainly not true. What is your teacher's explanation for why the E-field is non-zero? |
| Aug20-08, 05:05 AM | #7 |
Recognitions:
| Aug20-08, 05:30 AM | #8 |
Recognitions:
Gauss's law still works - after you solve for the E field the hard way, calculate the flux on your Gaussian surface, and you'll find that it is zero. In the case of a field with no spherical symmetry, it must be that some flux is pointing into the Gaussian surface, and some flux is pointing out of it, and those all cancel. Gauss's law works, but it just happens to be not very useful in this case. It's useful if you know the direction of the E field in advance from symmetry, then you can make a clever choice for the shape of the Gaussian surface to give you the magnitude of the E field. |
| Aug20-08, 05:50 AM | #9 |
Mentor
| Aug20-08, 06:03 AM | #10 |
Recognitions:
OK, I'm confused about a few things. Is the outer sphere a conductor? Is the inner sphere a conductor? Seems we need to know whether the charges can redistribute themselves. For example, the total charge on the inner conductor might be zero, but if the charges can move, then we may end up with a situation where the negative charge is gathered on one side, and the positive charge on another.
Actually, since you told us that it's equivalent to pretending that the inner sphere has charge density of -rho, that's equivalent to telling us which spheres are conducting ... |
| Aug20-08, 06:22 AM | #11 |
Recognitions:
OK, I get it I think. It's not a sphere of charge (ie. with charge on its surface only). It's a solid ball of charge with a hole that's off center. All the charge is fixed in place, so these are not conductors. That makes sense, since volume charge density is usually denoted rho, but surface charge density is usually denoted sigma.
| Aug20-08, 06:56 AM | #13 |
Mentor
To understand the difference between the E-field and the flux through a Gaussian surface, consider Gauss' law applied to the space between the plates of a capacitor. There is a uniform E-field in this region, but no charges. The E-field is non-zero, but the flux is zero because any E-field line that enters the surface must also leave the surface on the other side.
Whenever I get confused about flux v. field that is the example I think about. |
| Aug20-08, 08:41 AM | #14 |
Recognitions:
| Aug20-08, 09:02 AM | #15 |
Mentor
| Aug20-08, 10:21 AM | #16 |
Recognitions:
OK, what about an outer nonconducting sphere with uniform surface charge density sigma. Put a conducting sphere inside it that's off center. The inner conducting sphere has no net charge.
Will the E field inside the outer sphere be zero? (Edit: I think it will be, because if the outer sphere were a conductor, that would be a Faraday cage, and there would be no E field inside. If it were a conductor, the charge would be uniformly distributed. So the uniform charge distribution on the non-conducting sphere mimics that conducting sphere, so the E field will be zero) If it is, are we justified in using Gauss's law to do so, or does that just accidentally give the right answer, since we don't have spherical symmetry? (Edit: For example, how do we know that there isn't some separation of charge on the inner sphere, since part of it is nearer the charged outer wall than another part, since it is off center?) |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Gauss's law doesnt work here?
| Satellite Motion - This doesnt seem right... | Introductory Physics Homework | 4 | ||
| why doesnt sugar rot? | Biology | 6 | ||
| Right hand rule #2 doesnt work.. | Introductory Physics Homework | 4 | ||
| why nuclei doesnt colapse? | High Energy, Nuclear, Particle Physics | 4 | ||
| hit counter doesnt work | Computing & Technology | 2 | ||
