Uncovering the Mystery: How a Wheel and Axle Multiply Force in Simple Machines
  • Context: High School
  • Thread starter Thread starter Infrasound
    Machines
The discussion revolves around the mechanics of a wheel and axle as a simple machine, specifically focusing on how it multiplies force. Participants explore the underlying principles of force translation and the relationship between input and output forces, questioning the explanations typically provided in educational contexts.
  • One participant expresses confusion about how the axle exerts more force than the wheel, questioning the explanation that it is due to the force being exerted over a shorter distance.
  • Another participant suggests that the wheel and axle can be understood as a first-class lever, where a small force at the wheel translates into a larger force at the axle, maintaining that torque remains constant.
  • A participant challenges the notion that the force difference is simply a result of distance, seeking a deeper understanding of how forces can be balanced without movement.
Participants do not reach a consensus, as there are differing views on the mechanics of force translation in the wheel and axle system, with some seeking more fundamental explanations while others reference established mechanical principles.
Participants express uncertainty about the foundational concepts of force and distance in the context of simple machines, indicating a need for clarity on the relationship between these variables and how they apply to the wheel and axle mechanism.
Infrasound
Here is something that has been bothering me for quite a while...
Growing up, I was always taught that a wheel and axle decreased effort by multiplying the input force. In other words, the axle actually exerts more force than the wheel, just over a shorter distance.
This makes sense and conserves overall work, yet I am not completely satisfied with my current level of understanding.
WHY does the axle exert more force? How did the force get multiplied? To me, the "because it is can be exerted over a shorter distance" holds no ground, because it does not explain the balancing of two opposite but unequal forces using a wheel and axle. If they are indeed balanced, then the force is not exerted over a distance.
Sometimes I feel as if I am the only one who just does not get it.
How does the force increase?
Perhaps there is something obvious that I am not considering?
Do I have a serious mental disorder that is not allowing me to understand something simple?
I feel like I have lost it here.
Do you understand how a lever works? The wheel & axle can be viewed as a first class lever. A small force at the edge of the wheel translates into a large force at the axle, and vice versa. (Of course, the torque is the same.)
Yes, I understand that it is really just a first class lever, but WHY does the force translate to a different amount? To me, the force being applied over a smaller distance is just an inherent side effect, not the cause of the force being different at the two different radii. Thats what I wan't to know. How can the force be different if two different loads can be in balance? It's not moving then, so force is NOT being exerted over a distance.
I don't want this to be a situation where I have to use the "It just does" excuse. Let me get my barf bucket!
  • · Replies 52 ·
  • · Replies 60 ·
