Calculating the Momentum of a Proton with a Kinetic Energy of 750MeV
The discussion revolves around calculating the momentum of a proton with a kinetic energy of 750 MeV, utilizing principles from relativistic physics. Participants explore the relationship between energy, mass, and momentum in the context of high-energy particle physics.
  • Mixed
  • Participants attempt to apply energy equations to find momentum, questioning the correct application of relativistic versus non-relativistic formulas. Some express confusion about the conversion of mass units and the implications of kinetic energy being comparable to rest mass energy.
There is an ongoing exploration of different methods to calculate momentum, with some participants providing corrections and clarifications on the equations used. Multiple interpretations of the problem are being discussed, particularly regarding the conditions under which relativistic equations apply.
Participants note the importance of understanding the relativistic effects at the given kinetic energy, which is close to the rest mass energy of the proton. There is also mention of homework constraints and the need for clarity in the definitions used in the equations.
UAPhys03
What is the momentum of a proton with a kinetic energy of 750MeV?
E = m0c2 + K
E2 = p2c2 + m0c2
Mp = 1.67 x 10-21
I think what's confusing me is K = 750MeV, but I tried to solve for p
First, I converted 750MeV to 750x106 eV
Then solved for E in the first equation
E = 750x106 eV
Then used that to solve for p in the second equation
But i get a wrong answer.
The correct answer is 1404MeV/c
In your second equation, [tex]m_oc^2[/tex] needs to be squared. So it should be [tex]E^2 = p^2c^2 + (m_oc^2)^2[/tex]
You also need to express the proton mass in electronvolts. Are you doing that?
E = m0c2 + K
E2 = p2c2 + m0c2
Mp = 1.67 x 10-21
E = 750x106 eV
In other words, you get that E = K. But that's only true when m0=0, which is not the case for a proton.
You did mean to say proton, and not photon?
Hey,
So I fixed the equation and figured it out
E = m0c2 + KE
m0c2 = 1.5x10-10j = 939.4MeV
E = 939 + 750 = 1689MeV
E2 = p2c2 + m02c2
16892 = p2c2 + 9392
p2c2 = 191000
pc = 1404MeV
p = 1404MeV/c
Thanks!
is it okay to solve like this??
1/2(Mp)v2=K
1/2(p2)/Mp=K
p=square root of 2K(Mp)
p=6.34x10^-19 kg m/s
UAPhys03 said:
Hey,
E = m0c2 + KE
E2 = p2c2 + m02c2
16892 = p2c2 + 9392
p2c2 = 191000
pc = 1404MeV
p = 1404MeV/c
Thanks!
Your arithmetic is not correct. It should be: p2c2 = 1,970,000
AM
1/2(Mp)v2=K
1/2(p2)/Mp=K
Not for relativistic speeds. A proton with 750 Mev of kinetic energy is moving at relativistic speed. At non-relativistic speed you can use:
[tex]\text{KE} = \frac{1}{2}mv^2 = \frac{p^2}{2m}[/tex]
[tex]p = \sqrt{2m\text{KE}}[/tex]
You had it right if you were using Mp for proton mass and p for momentum, but it is confusing.
AM
AM
How can i know whether it is in non-relativistic or relativistic speed?
For non-relativistic speeds, KE has to be a lot less than mc2. Equivalently, this means the speed is a lot less than c.
In this problem, KE is 750 MeV. That is comparable to mc2 = 940 MeV, so it is relativistic in this case.
So for relativistic speed wouldn't you just substitute that equation,
K = 1/2((lorenz factor) - 1)mv2
substitute for p
K/((lorenz factor) - 1) = p2/2m
and you could figure out how fast the proton is moving given the kinetic energy?
No, the relation is
K = ( (Lorenz factor) - 1 ) m c2
Given K, solve for the Lorenz factor, from which you can get v.
So can i use E=hf to calculate the momentum as it's relativistic??
Why would you think that? Momentum does not appear anywhere in your equation ?
i thought the wavelength in the equation E=hc/lambda is the same as the de Broglie's wavelength...
is the de Broglie's wavelength of a electron with non-relativistic speed couldn't be sub into the E=hf equation??
Sometimes, not always. There actually 3 "speed regimes", not 2, to think about.
1. Non-relativistic: K is much less than mc2
2. Moderately relativistic: K is comparable to mc2
3. Extremely relativistic: K is much larger than mc2
That equation, E = hf = hc/lambda = pc , is valid in the extremely relativistic case. Another way of seeing this is from two equations that are true in all 3 cases:
E2 = (pc)2 + (mc2)2
and
E = K + mc2
In case 3 (and only then) we can neglect the mc2 terms because it is much smaller than the other quantities, and we get
E = K = pc (and also E = hc/lambda = hf)
Hope that helps.
o,
finally i understood!
thnx ya!
  • · Replies 54 ·
12K
