Solve y'''=y'': Using Power Series to Solve Non-Linear Diff Eq
  • Context: Graduate
  • Thread starter Thread starter lkj-17
The discussion focuses on solving the non-linear differential equation y''' = y'' using power series and integration techniques. Participants explore various methods to derive solutions, including assumptions about initial conditions and the use of integrals involving the Exponential Integral function.
  • One participant inquires about the use of power series to solve the equation.
  • Another participant proposes assuming initial conditions y(0) = A, y'(0) = B, and y''(0) = C, and derives a series expansion for y(x) based on these assumptions.
  • A different approach is suggested, where the equation is rearranged to y''' = y''/y' and integrated to yield y'' = κ + ln(y'), introducing constants of integration.
  • This participant further discusses the integration of the resulting expression and references the Exponential Integral function, providing a formula for y' and suggesting numerical techniques for obtaining values for y(x).
  • A correction is made regarding the expression for y(x), clarifying the integration constant used in the formula.
Participants present multiple competing views on how to approach the solution, with no consensus reached on a single method or final expression for y(x).
Limitations include dependence on initial conditions and the complexity of integrating expressions involving the Exponential Integral function, which remains unresolved.
lkj-17
How to use power series to solve this non-linear differential equation?
First, because this is a third order equation, its general solution will involve 3 undetermined constants. So, assume y(0)= A, y'(0)= B, y"(0)= C.
From y'y"'= y", y"'= y"/y' and so y"'(0)= C/B. Now, differentiating y"'= y"/y' again, yiv= (y'y"'- y"2)/y'2 so yiv(0)= (B(C/B)- C^2)/B2= (C- C2)/B2.
So far, we have y(x)= y(0)+ y'(0)x+ (1/2)y"(0)x2+ (1/3!)y"'(0)x3+ (1/4!)yiv(0)x4+ ...= A+ Bx+ (1/2)Cx2+ (1/6)(C/B)x3+ (1/24){(C- C2)/B2}x^4+ ...
Continue like that to get higher terms.
Re-arrange your equation as
[tex]y^{\prime \prime \prime} = \frac{y^{\prime \prime}}{y^{\prime}}[/tex]
Now integrate with respect to x to get
[tex]y^{\prime \prime} = \kappa + \ln{y^{\prime}}[/tex]
where [tex]\kappa[/tex] is a constant of integration. Now re-arrange and integrate to get
[tex]\int{\frac{d y^{\prime}}{\kappa + \ln{y^{\prime}}} = x + \epsilon[/tex]
where [tex]\epsilon[/tex] is another constant.
I checked the Integrator (Wolfram site), and it gave the integral as:
[tex]\int{\frac{dw}{a + \ln{w}}} = e^{-a}Ei(a + \ln{w})[/tex]
where [tex]Ei[/tex] is the Exponential Integral.
Hence we can apply this to our integral to get
[tex]e^{- \kappa} Ei(\kappa + \ln{y^{\prime}) = x + \epsilon[/tex]
which we can re-arrange as
[tex]y^{\prime} = exp(Ei^{-1}(e^{\kappa}(x + \epsilon)) - \kappa)[/tex]
We can tidy this up a bit by making
[tex]e^{\kappa} = \alpha[/tex]
and
[tex]\epsilon \alpha = \beta[/tex]
and then integrate to get
[tex]y(x) = \frac{1}{\beta}\int{exp(Ei^{-1}(\alpha x + \beta)) dx}[/tex]
and then you'll have to try some numerical techniques to obtain values for y(x) (I have to idea how to express the inverse of "Ei".)
Sorry that should read:
[tex]y(x) = \frac{1}{\alpha}\int{exp(Ei^{-1}(\alpha x + \beta)) dx}[/tex]
  • · Replies 24 ·
