Is the integral of a non-negative function always positive?
  • Context: Undergrad
  • Thread starter Thread starter jenga42
    Inequality
The discussion centers around the properties of integrals of non-negative functions, specifically whether the integral of a product of a non-negative function and another function maintains certain inequalities. Participants explore conditions under which the inequality holds, particularly focusing on the implications of the positivity of the function involved.
  • Jenny questions whether, given two functions a(x) and b(x) where a(x) < b(x) over an interval, the inequality ∫_{x_i}^{x_f} f(x) a(x) dx < ∫_{x_i}^{x_f} f(x) b(x) dx holds true when f(x) > 0.
  • Some participants suggest that continuity of f may be necessary for certain estimates, while others argue that the monotonicity of integrals suffices.
  • One participant proposes using the definition of the integral to show that if c(x) is non-negative, then ∫_{x_i}^{x_f} c(x) dx ≥ 0, which could help in proving the original inequality.
  • There is a suggestion that multiplying both sides of the inequality a(x) < b(x) by f(x) preserves the inequality due to f(x) being positive.
  • Participants express uncertainty about the implications of monotonicity and the conditions under which the inequalities hold.
Participants do not reach a consensus on whether a general theorem exists to support the inequality in question. There are competing views on the necessity of continuity and the implications of monotonicity in integrals.
Some participants express confusion regarding the definitions and implications of monotonic functions and the conditions under which the inequalities can be applied. There are references to specific cases and assumptions that may limit the generality of the claims made.
jenga42
Hello,
I'm trying to figure out if this is true - any help would be greatly appreciated!
If a(x) < b(x) between the values x_i and x_f then is the following also true?...
int_{x_i}^{x_f} dx f(x) a(x) < int_{x_i}^{x_f} dx f(x) b(x)
where f(x)>0 for all x.
...I think it is true, but I'd like to be able to prove it!
Thanks,
Jenny
Your notation is a bit awkward. Are f(x)a(x) and f(x)b(x) the integrands?
If f is continuous (you will definitely need that, I think) and the interval is finite, then you could probably estimate it by its maximum and do a series of inequalities like
[tex]| \int_a^b f(x) p(x) dx | < | f(x) p(x) (b - a) | < \cdots[/tex]
Or you could try considering
[tex]\int_a^b f(x) (p(x) - q(x) )[/tex]
and showing that it is positive (for q(x) < p(x) everywhere).
You don't need continuity or anything of the sort -- the integral is monotone. That is, if h and k are integrable on [a,b], and h(x)<=k(x) for all x in [a,b], then
[tex]\int_a^b h(x) dx \leq \int_a^b k(x) dx.[/tex]
Edit: Oh. Maybe that's what you were saying here:
Hi,
Thanks for replying! I didn't know I could type the equations!
Just to clarify, I meant if a(x)<b(x), can I say
[tex]\int_{x_i}^{x_f} f(x) a(x) dx < \int_{x_i}^{x_f} f(x) b(x) dx[/tex]
where f(x)>0.
I'd like to know if there is a general theorem for this to be true? ...I think that (please correct me if I'm wrong!) I could only use
for a specific f(x).
What does "the integral is monotone" mean?
Thanks!
I've just had a thought, can I just say that as f(x)>0, then it cannot change the direction of the inequality, hence if a(x)<b(x) , then multiplying both sides by f(x), we find f(x)a(x)<f(x)b(x) and therefore
[tex]\int_{x_i}^{x_f} f(x)a(x) dx < \int_{x_i}^{x_f} f(x)b(x) dx[/tex]
This is assuming that if a(x)<b(x), then
[tex]\int_{x_i}^{x_f} a(x) dx < \int_{x_i}^{x_f} b(x) dx[/tex]
But I don't understand why this second equation is true - I've tried looking up monotone functions, but haven't found anything useful!
Thanks
That's perfect. (But you should be using [itex]\leq[/itex] instead of [itex]<[/itex].)
This should be straightforward to prove if you just use the definition of the integral. To make it even easier, you can prove the following:
If c(x) is integrable on [x_i, x_f] and if c(x)>=0 for all x in [x_i, x_f], then
[tex]\int_{x_i}^{x_f} c(x) \geq 0.[/tex]
[Once you do this, you can put c(x)=b(x)-a(x) to get the result you want.]
  • · Replies 24 ·
  • · Replies 16 ·
  • · Replies 30 ·
  • · Replies 31 ·
