Finding E(X^2) for a Beta Distribution
  • Thread starter Thread starter laura_a
    Beta Distribution
The discussion focuses on calculating E(X^2) for a Beta distribution with parameters m = n = θ. The user initially identifies that E(X) = 1/2 and seeks to derive E(X^2), ultimately finding that E(X^2) = (θ + 1) / (2(2θ + 1)). The user also references the relationship between variance and expected values, noting that variance is defined as Var(X) = E(X)^2 - E(X^2). The user successfully resolves the problem by applying the variance formula.
  • Understanding of Beta distribution properties
  • Knowledge of expected value calculations
  • Familiarity with variance and its relationship to expected values
  • Basic proficiency in statistical methods and formulas
  • Study the derivation of E(X^2) for various distributions
  • Explore the Method of Moments for parameter estimation
  • Learn about the properties and applications of Beta distributions
  • Investigate the relationship between variance and expected values in depth
Students studying statistics, mathematicians focusing on probability distributions, and anyone involved in statistical modeling using Beta distributions.
laura_a
The actual question I'm working on is to find the Method of moments for \theta for a beta distribution where the parameters are m = n= \theta
What I need help with is to get started, I know that E(X)=1/2 for this question so that it does not depend on \theta My actual problem is that I need to calculate E(X^2) and I can't find any info on how to calculat E(X^2) for a beta distribution, I know the answer is (\theta +1)/(2(2\theta +1))
I found a formula on Wiki for Variance of a beta distribution and thought i'd try it, although I know that variance is E(X)^2 - E(X^2) anyway I ended up with 1/(4(2\theta +1)) which was close, but not it... Once I find E(X^2) I should be able to answer the actual question I'm working on
ahh don't worry I've figured it out, I've got E(X) and I've got Var(X) so I'll find E(X^2) using that formula for variance... thanks anyway
  • · Replies 18 ·
