Turning radius and wheel speed difference
The discussion revolves around determining the turning radius of a simple car with front wheel steering, specifically focusing on the relationship between the velocity difference of the front wheels and the turning radius. Participants explore theoretical aspects and mathematical relationships involved in this context.
  • Rana Basheer expresses difficulty in relating the turning radius to the velocity difference between the front wheels, despite understanding the relationship between steering angle and turn radius.
  • One participant suggests that the turning radius depends solely on the angle of the front wheels and mentions a tracking arrangement on the front axle that may influence wheel speeds.
  • Another participant explains the role of the differential in a car, stating that the outer wheel must turn faster than the inner wheel, and presents equations relating wheel speeds to turning radius.
  • A participant expresses interest in testing the proposed equation on an RC car to verify its accuracy.
  • Another participant questions the derivation of the equation provided, noting a discrepancy with their own calculation and seeking clarification on the derivation process.
Participants have differing views on the relationship between turning radius and wheel speed differences, with some proposing equations that do not align. The discussion remains unresolved regarding the correct formulation and derivation of these relationships.
There are unresolved mathematical steps and potential dependencies on definitions that participants have not fully clarified, particularly regarding the derivation of the equations presented.
ranabasheer
I am trying to fitgure out the turning radius of a simple car with front wheel steering based on the velocity difference between the front wheels. Unfortunately, I could not figure out how this could be done. I figured out the relationship between steering angle and turn radius but I am unable to relate that to the wheel speed difference. Any help is greatly appreciated.
Thanks and Regards
Rana Basheer
Welcome to PF!
Hi Rana! Welcome to PF! :smile:
I think the turning radius depends only on the angle of the front wheels.
I expect you're thinking that the outer wheel has to go further than the inner wheel, and so must go faster … but I think there's some sort of tracking arrangement on the front axle so that that doesn't happen (I honestly don't really understand that part of it :redface:)!
Anyway, imagine a three-wheeled car, with only one front wheel … it still turns, doesn't it? :wink:
He is referring to the purpose of the differential in the car. Basically that the outer wheel (wrt the turn) must turn faster than the inner wheel and this relationship or ratio of the two speeds is a function of the turning radius of the car.
It can be easily shown that
wt * rt = ww * rw
and
rt = ro - wb/2, rt = ri+wb/2
where:
wt = angular velocity of the car
wb = wheel base of the car (width)
rt = radius of the turn
ww = angular velocity of the wheel (wo,wi as outside and inside)
rw = radius of the wheel
ro = outside radius of tire
ri = inside radius of tire
With a little coaxing and simple algebra you get this:
rt = [tex]\frac{-Wb}{2}[/tex] [tex]\frac{wi+wo}{wi-wo}[/tex]
Thank you topher,
I appreciate your help. I never looked at that way. I will test your equation on my RC car and let you know how accurate my turning radius are.
hey Topher925
i jus read ur post cos i had the same question.. now can u explain how did u derive it.. ? cos according to my calculation rt= rw - (Wb/2)(wi+wo)/(wi-wo) but urs say differently... let me know how u got the equation.
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 49 ·
  • · Replies 19 ·
