syano
- 82
If the Earth did not have an atmosphere could you make a golf ball orbit the Earth just 1 foot above the highest point of the crust of the Earth?
The discussion explores the concept of orbital mechanics, particularly focusing on the hypothetical scenario of a golf ball orbiting the Earth at a very low altitude, specifically without an atmosphere. Participants examine the factors influencing orbital speed, the effects of Earth's rotation, and the implications of gravitational forces at varying distances.
Participants express a range of views on the factors affecting orbital mechanics, with some agreeing on the basic principles while others challenge specific claims or interpretations. The discussion remains unresolved on several points, particularly regarding the influence of Earth's rotation and the precision required for maintaining orbits.
There are limitations in the discussion regarding assumptions about gravitational uniformity, the effects of atmospheric drag, and the specific conditions required for maintaining orbits at various altitudes. The mathematical relationships presented are subject to interpretation and correction.
syano said:Is this right...the closer the golf ball is to Earth the faster it will need to move to maintain a steady orbit?
That's wrong.ShawnD said:[tex]V^2 = \frac{Gm_1m_2}{r}[/tex]
Gokul43201 said:2. None. Any change in the one will cause a change in the other. If the velocity is low by 1%, the station will approach Earth at an acceleration of about '2% of g' or 0.2 m/s^2. In the first 10 seconds the orbit will drop by 10 m. 2 minutes later, it will be closer by about a mile, and 10 minutes later, by 100 miles. The way to get it right is to (i) to be close at the beginning and then (ii)continuously monitor and adjust.
3. I think the Blackbird has turbofan engines which requires oxygen to burn the fuel.
4. The escape velocity depends on the drag from the atmosphere. There will be less drag in the moons atmosphere, since that's much thinner, so you'll need a smaller addition to compensate for drag. However, this number is not one-sixth that of Earth's. The escape vleocity (neglecting drag) is SQRT(2*G*M/R). I don't know the ratio of the masses and radii, but if you plug them in, you get the ratio of the rough escape velocities.
5. To quantify how much harder it would be, you would need to specify the orbital height (and perhaps, several other things). There may be other complications involved in stability and control, but typically, the required take off velocity will have to be greater by about 1%. This, however, is not a small number, when it comes to fuel costs and such.
Nereid said:Going east, you get the Earth's speed at the launch point (relative to the centre of the Earth) 'for free', and if you're on the equator, you maximise it. That's why the ESA's main launch site Kourou is only 5o N, the US's in Florida, and Russia's in Kazakhstan. IIRC, Israel, when it launched its first spacecraft , wanted to launch west (for political reasons).
