Mass & Acceleration: Does Zero Mass Mean Infinite Acceleration?
The discussion revolves around the implications of an object having zero mass in relation to acceleration, exploring concepts from classical mechanics and relativistic physics. Participants examine the theoretical consequences of zero mass, including potential infinite acceleration and the physical reality of such objects.
  • Some participants suggest that if mass is the property resisting change in motion, then an object with zero mass could theoretically have infinite acceleration.
  • Others clarify that the statement about mass and acceleration should consider the force applied, indicating that zero mass could lead to infinite acceleration only if a force acts upon it.
  • One participant notes that photons, which have zero rest mass, do not experience acceleration in the classical sense, as they are not affected by forces.
  • Another participant challenges the notion of zero mass, arguing that classical physics does not support the existence of such an object, as it leads to undefined situations like division by zero.
  • Some participants discuss the concept of fluid particles, debating whether they can be considered to have zero mass and how this relates to the mathematical abstraction versus physical reality.
  • There is a contention regarding the definitions of mass, with references to relativistic mass and the implications of momentum in relation to mass.
  • Participants also discuss the historical context of physical theories, particularly the transition from classical to molecular models and the limitations of continuum mechanics.
Participants express multiple competing views on the implications of zero mass and its relationship to acceleration. There is no consensus on whether an object with zero mass can exist in a meaningful physical sense or the implications of such a concept.
The discussion highlights limitations in definitions and assumptions regarding mass and acceleration, particularly in the context of classical versus relativistic physics. The debate also touches on the applicability of continuum mechanics at different scales.
deadskint
i have just read while revising for my physics AS exam that
'Mass is the property of an object which resists change in motion'
'An object with larger mass will accelerate less than the object with smaller mass'
does this not imply that an object with zero mass will have infinite acceleration?
and does having infinite acceleration therefore imply the object has the ability to be everywhere at the same time??
Surely that quote should be 'An object with larger mass will accelerate less than the object with smaller mass WHEN SUBJECT TO THE SAME FORCE'
It implies that an object with zero mass COULD have infinite acceleration if it were affected by some force.
The only objects with zero mass are photons and they are not affected by forces- they have 0 acceleration.
A photon is considered to have an actual mass of zero and a zero rest mass, but when the photon is moving, it assumes an apparent mass due to the velocity (m = E /C2). This apparent mass is significant enough to lend to uncertainties in momentum and position according to Heisenberg.
That is incorrect. A photon has a non-zero (relativistic) mass. Only its rest mass is zero. However this could be a disagreement in terms since the terms "apparent mass" and "actual mass" are not terms that are defined in relativity. At least not in the more well known literature.
Relativistic mass "m" equals the ratio of the magnitude of the particles momentum to its speed. I.e. m = p/v. For a photon v = c. Since E = pc => c/E then
m = p/c = (E/c)/c = E/c2
Pete
Well if we stay at Newtons theory then the answer is clearly No.
F = m * a --> a = F/m if m = 0 we will divide by zero which isn't aloud.
There's no (classical) physical reality of an object with zero mass... it has no physical meaning. Something cannot have an infinite acceleration if it doesn't exist.
Sure there is; fluid particles for example.
(They don't have infinite accelerations, though, since the sum of forces acting upon them is zero)
Fluid particles have mass. Anything that has momentum has mass (note: That
s mass, and not rest mass that I'm referring to).
Pete
Any REAL fluid particle/collection of atoms have mass;
the mathematical abstraction known as a fluid particle (which is what I was talking about) occupies a single, spatial point, with a non-zero density value attached to it.
The mass of a fluid region V is given by:
[tex]M=\int_{V}\rho{dV}[/tex].
Going to the limit [tex]V\rightarrow0[/tex] yields the mass of a single, mathematical, fluid particle
You say it yourself. It's a mathematical abstraction... in other words not to be confused with physical reality.
Do note that I don't know anything about the fluid particle you're talking about.
Lorentz said:
You say it yourself. It's a mathematical abstraction... e.g. not to be confused with physical reality.
You used the term (classical) physical reality, in the first place, and that's what I've referred to.
Up to the development of the atomic theory in the middle 19'th century,
"reality" consisted for physicists in the existence of continua/continuums,
in which such particles were thought to exist.
With the advent of the molecular model, the mathematics developed in earlier times could be overtaken almost unchanged; however, a lower limit of applicability of the continuum hypotheses had now to be introduced
(i.e. continuum mechanics do not accurately describe the behaviour at length scales comparable with the mean free path, for example).
Have you ever calculated in solid mechanics the moment of inertia by integral?
If you have done so, you are using a continuum mechanics model of reality.
  • · Replies 46 ·
  • · Replies 39 ·
  • · Replies 41 ·
