Negative potential energy and coulomb force
The discussion revolves around the concepts of potential energy and force in the context of Coulomb's law, particularly focusing on the implications of negative potential energy and the nature of attractive and repulsive forces between charged particles.
  • Conceptual clarification, Assumption checking, Exploratory
  • Participants explore the relationship between negative potential energy and attractive forces, questioning how these concepts interact in various scenarios, including the binding energy of electrons in atoms.
There are multiple interpretations being explored regarding the nature of forces and potential energy. Some participants provide insights into the implications of negative potential energy, while others seek clarification on how these concepts apply to specific examples, such as the behavior of electrons in hydrogen atoms.
Participants are navigating the conventions of potential energy, particularly the zero point being at infinity, and how this affects the interpretation of forces and energy in bound systems. There are also discussions about the implications of moving charges and the associated forces that arise from changes in potential energy.
learning_phys
The coulomb force is given by k*q1*q2/r^2 so if there are two charges that have negative signs, then the force would be negative. Having said that, a "negative force" would then signal an attractive force since opposites attract.
F=-dU/dx, so a negative force would result in a "positive potential"
Does this mean a positive potential is attractive and a negative potential is repulsive? I'm not sure why there is a negative sign there. If this is the case, then why is the binding energy for an electron around the hydrogen atom -13.6 eV? The energy here is negatice, but the force is "binding"
I'm confused, any thoughts would be appreciated.
The + and - simply mean how the system is bound. For example, the - sign in gravity simply implies that unless one piece of matter is infinitely far from the others, that particle remains bound to the others; however, the gravitational force between matter is naturally attractive and so the gravitational potential energy is naturally bound to values increasing in magnitude below 0J. A + sign implies that the system is not bound, meaning that if 2 charges repel, the electric potential energy draws closer to 0J naturally.
so how does force play into this? an attractive (negative) force results in a unbounded (positive) potential?
Not a positive potential necessarily, but a positive rate of change of potential. Meaning: If the force points to the left, then the potential energy increases to the right.
If, as the particles are separated, the potential energy increases, then the force between them is attractive.
Realize that the zero point for potential energy is when the electron is far away from the nucleus. Compared to that point, the ground state electron PE is -13.6 eV. Thus, to move the electron from the atom requires energy to be added. (And thus the force is attractive, since moving the electron further out increases the potential energy.)
Say we have two equal charges of equal mass and opposite sign. Charge A is -q and charge B is q, with the potential =0 and charge A at rest and charge B has an initial velocity towards A of v. So, as charge A goes towards charge B, then potential energy becomes NEGATIVE since it takes energy to pull them apart... however, this is counteracted by the increaseing kinetic energy... thus the total energy of the system will always be 0.5mv^2 right? (ignoring effects of radiation)
Sure. As the charges get closer their potential energy decreases while their kinetic energy increases. The total energy remains constant.
and by decrease, you mean "increase negatively" just like how the electron has a potential of -13.6eV
does this mean the electron around the hydrogen atom can never have a positive potential?
Sure, if you want to express it like that. But realize that it's not the sign of the potential that matters but how it changes.
Right. As long as you take the usual convention of electric PE being zero at infinity, the electron in a hydrogen atom can never have a positive potential.
If the particles are separated, the potential energy increses, then dU/dx is always positive, thus the force is always negative, then does this mean a negative force is always attractive?
Doc Al said:
Realize that the zero point for potential energy is when the electron is far away from the nucleus. Compared to that point, the ground state electron PE is -13.6 eV. Thus, to move the electron from the atom requires energy to be added. (And thus the force is attractive, since moving the electron further out increases the potential energy.).
In this case, if the electron was moved from -13.6 to infinity, then the change in potential energy is positive, but this makes the force negative... does this mean that a negative force increases a potential (instead of saying a negative force means an attractive force)
It depends on what you mean by "negative"--that's a sign convention.
Let x represent the separation of particle B with respect to particle A. As x increases, B gets further away. Since dU/dx is positive, the force is negative and thus points in the negative x direction. That means the force on B points towards A, and thus is an attractive force.
Read what I just wrote above and rephrase the question if I missed it.
the coulomb force is attractive between the two charges, but why is the force that is needed to move charge B away not taken into account?
also, what if we let the charge B move towards charge A, then since the potential is decreasing, dU/dx<0, making the force positive?
Not sure what you mean. The force needed to (just) move charge B away is equal and opposite to the Coulomb force. (Assuming charge A is fixed.)
F = -dU/dx gives you the force associated with the potential. Any other force is up to you.
dU/dx is still > 0. The slope of U, and the associated force, doesn't change just because the charge is moving one way or the other.
  • · Replies 29 ·
  • · Replies 22 ·
  • · Replies 17 ·
