How Long Does It Take for a Transverse Wave to Travel Through a Whirling Rope?
  • Thread starter Thread starter kidsmoker
    String Wave
The problem involves a uniform rope being whirled in a horizontal circle, with the task of determining the time it takes for a transverse wave to travel along the rope. Key parameters include the rope's length, mass, angular velocity, and the assumption that gravity can be ignored.
  • Participants discuss the implications of ignoring gravity on the tension in the rope and question how centripetal force relates to tension. There is confusion regarding the variables involved, particularly the radius of circular motion and its relationship to the rope's length.
The discussion is ongoing, with participants exploring different interpretations of the problem setup. Some have provided insights into the relationship between tension and circular motion, while others express uncertainty about their understanding of the problem's parameters.
There is a noted confusion regarding the orientation of the rope and whether it is being treated as hanging or horizontal. This misunderstanding has led to varied interpretations of the problem's requirements.
kidsmoker
"A uniform rope with length L and mass m is held at one end and whirled in a horizontal circle with angular velocity w. You can ignore the force of gravity on the rope. Find the time required for a transerve wave to travel from one end of the rope to the other."
w = 2*pi*f
wave speed = frequency*wavelength = sqrt(tension/mass per unit length)
I'm a bit confused here. If the force of gravity on the rope is being ignored, then what is the tension in the rope?
Hi kidsmoker,
w = 2*pi*f
Think about what has to be true for the mass to travel in a circular path.
There's a force mw^2A acting towards the centre? Do I take this as the tension in the string? I'm still not sure what to do sorry...
What is "A" in your equation?
Sorry, the radius of the circular motion. I called it A cos it's like the amplitude.
In your problem that is actually "L" and yes that is the centripetal force on the string which is your Tension that you are looking for.
Are you sure? Why would it be equal to the length of the string?
Perhaps this will help?
http://hyperphysics.phy-astr.gsu.edu/hbase/cf.html#cf
Wait a minute is there a mass at the end of the rope or is the rope itself mass M total?
Maybe I am misreading the problem?
I ws completely misreading the question too. I thought that the string was hanging vertically and you were whirling the top end in a circle, so that these circular waves travel down the string. I realize now that it means that the whole string is horizontal and it's being whirled in a circle like this, so as to keep it taut. In that case the problem is easy :P
Thanks anyway!
  • · Replies 29 ·
  • · Replies 39 ·
