| Thread Closed |
a logical question.. |
Share Thread | Thread Tools |
| Aug12-08, 04:50 PM | #1 |
on a table we arrange in a line four stones.
two of them are small two of them are large two of them are green two of them are purple which one of the answers are not needed in order to determine the exact order of this stones? 1.each green stone stayes between a big stone and a small stone 2.both of the big stones are close one to the another 3.the stone on the right edge is purple 4.the green stones have the same size i dont know where to start how to deside what answer to start with?? i dont know how to find this answer ?? |
| Aug12-08, 05:18 PM | #2 |
1. "each green stone stayes between a big stone and a small stone"
Spoiler
Well, #1 tells you quite a bit. Each green stone is between two stones, one big, one small. Hence, you can conclude that:
A) neither green stone is on an end B) both green stones are in the middle C) because the stones are either green or purple, the stones on the ends are necessarily purple. So it goes Purple, Green, Green, Purple. D) the 1st and 3rd cannot both match in size E) the 2nd and 4th cannot both match in size F) The order is necessarily one of: - Big, Big, Small, Small - Big, Small, Small, Big - Small, Big, Big, Small - Small, Small, Big, Big That one clue told us a LOT. 2. "both of the big stones are close one to the another"
Spoiler
This tells us that the order is one of:
- Big, Big, Small, Small - Small, Big, Big, Small - Small, Small, Big, Big 3. "the stone on the right edge is purple"
Spoiler
This tells us nothing new. Already, we know that this is the useless piece of information. All it tells us is that the order is one of:
- Green, Green, Purple, Purple - Green, Purple, Green, Purple - Purple, Green, Green, Purple But we already know the EXACT order of the colors thanks to #1. Hence, without even looking at the rest of the clues, we know the answer is #3, because #3 told us only a small chunk of what #1 already told us. So any conclusion we can make with #3 could be equally made with #1, therefore #3 is extraneous. But we can keep going anyway. 4. "the green stones have the same size"
Spoiler
That's helpful. It doesn't tell us anything directly about the order, but with #1 and #3, it tells us exactly what we needed to know. All together
Spoiler
With #1, we know the Color order is: Purple, Green, Green, Purple And we know the size order is one of: I. Big, Big, Small, Small II. Big, Small, Small, Big III. Small, Big, Big, Small IV. Small, Small, Big, Big So, after clue #1, all that remains is to figure out which order the sizes are in. With clue #2, we can eliminate possibility II, because the big stones must be close to each other. The remaining options are: I. Big, Big, Small, Small III. Small, Big, Big, Small IV. Small, Small, Big, Big With clue #4 (clue #3 tells us nothing new), we know that since the green's must have the same size, therefore the two in the middle must have the same size, hence eliminating possibilities I and IV. So the only remaining possibility is: III. Small, Big, Big, Small Clearly, because #3 told us something that we already learned from #1, #3 is a correct answer to the question. However, the question is (in our due diligence) whether #1 is necessary? Suppose we didn't have clue #1. We would know: 2.both of the big stones are close one to the another 3.the stone on the right edge is purple 4.the green stones have the same size So we'd know the size order is one of: - Big, Big, Small, Small - Small, Big, Big, Small - Small, Small, Big, Big And we'd know the color order could be: - Green, Green, Purple, Purple - Purple, Green, Green, Purple But we wouldn't know which of those would be correct. Hence, #1 is clearly necessary (as it should be, since it told us a LOT of information). DaveE |
| Aug12-08, 06:39 PM | #3 |
ye but we you also could say that the second answer comes from the first
answer because one of the conclusions that comes from the first answer is that the first and third rocks differ in size and so does the 2nd and 4th. in the second answer we get the same conclusion so the 2nd one is unnecessary where is my mistake??? |
| Aug12-08, 07:23 PM | #4 |
i havnt bothered to work it out but if you dont know where to start
to answer you question: leave out clue no.1 can you solve with only clues 2,3,4 if not then leave out clue no.2 can you solve with only clues 1,3,4 if not then leave out clue no.3 can you solve with only clues 1,2,4 etc etc eventually you'll find that you dont need one of the clues |
| Aug12-08, 07:47 PM | #5 |
Are you sure this is not a homework in axiomatics?
| Aug12-08, 07:48 PM | #6 |
You're correct that the 1st and 3rd differ in size, and the 2nd and 4th differ in size, BUT that doesn't necessarily mean that the big stones are close together. Using only clue #1, a potential arrangement would be: Big, Small, Small, Big 1st and 3rd differ in size (Big/Small), and 2nd and 4th differ in size (Small/Big), so it's totally valid, even though the two "Big" stones are as far apart as possible. DaveE |
| Aug13-08, 11:58 AM | #7 |
thanks
i understand your solution |
| Aug13-08, 01:02 PM | #8 |
i dont know if this is axiomatics
but i need to learn solving this kind of questions for "asat" exam in my country |
| Thread Closed |
| Thread Tools | |
Similar Threads for: a logical question..
| a logical question.. | Brain Teasers | 20 | ||
| logical question.. | Brain Teasers | 7 | ||
| logical question.. | Brain Teasers | 4 | ||
| I need a logical justification for this question??? | Biology | 27 | ||
| Logical Question | Brain Teasers | 9 | ||
