Confused about the difference between equivalence and implication
The discussion revolves around the concepts of equivalence and implication in mathematical reasoning, particularly in the context of equations involving square roots and inequalities. Participants explore the logical relationships between statements and clarify misunderstandings regarding their definitions and implications.
  • One participant questions the relationship between the statements a^2=c and a=c^(1/2), suggesting that they are equivalent, but later realizes that taking square roots introduces ambiguity with the negative root.
  • Another participant clarifies that implication means something must logically follow from something else, and defines equivalence as mutual implication.
  • There is a discussion about the notation "a = b" and its potential confusion with equality versus equivalence, with some participants expressing discomfort with this shorthand.
  • A participant points out that the statement a >= b and b >= a does not imply a = b, while the reverse is true, indicating a misunderstanding of implications in inequalities.
  • Further clarification is provided that the notation ">=" suggests a discussion of inequality rather than implication.
Participants generally agree on the definitions of implication and equivalence, but there is disagreement regarding the implications of specific mathematical statements and the appropriateness of certain notations. The discussion remains unresolved on some points, particularly regarding the clarity of notation and its implications.
Some statements made by participants depend on specific interpretations of mathematical notation and definitions, which may not be universally accepted. The discussion includes unresolved nuances regarding the implications of taking square roots and the logical structure of inequalities.
torquerotates
This is a really basic question that I don't know why I'm not getting. So from my understanding, a=b is defined as a=>b and b=>a.
So say a^2=c and a=c^(1/2)
so which implies which?
Say I start from a=c^(1/2)
I square both sides and I get a^2=c. So a=c^(1/2) => a^2=c.
But if I start from a^2=c, by taking the square root of both sides, I get a=c^(1/2) & -c^(1/2)
But since I got a=c^(1/2) among one of them, I have shown that a=c^(1/2) is still implied by a^2=c.
So a^2=c <=> a=c^(1/2)
Which is clearly not true. they are not the same b/c by taking the square root of both sides we get a=+ or -c^(1/2). Is there something wrong with my reasoning?
You did understand it correctly. Implication means, that something must logically follow from something else. For example: a > 1 implies that a > 0. If a > 1, you can reason logically and anyone (accepting your basic axioms and logical system, of course) could not deny the conclusion a > 0.
If two things imply each other, we call them equivalent. So if a => b and b => a we write a <=> b. I think a = b is a bad shorthand, because it makes you think of equality which it is not. The name "equivalence" is clear: the two things are either both true, or they are both false. If you know one of them, you know them both; therefore you can interchange them. For example, a > 0 is equivalent to (-a) < 0. I don't need to state them both, you can infer one from the other one.
Yes, the error in your example is in this line:
If you are trying to give a logically sound proof here, you should have written: a = c^(1/2) or a = - c^(1/2). It cannot be and, because they are different values and a cannot be equal to the two of them at the same time. And because it says "or" it doesn't follow that it is specifically one of the two (just that, if it isn't one, then it is the other).
Oh, ok. So because its a "or", it could be either so a^2=c does not => a=c^(1/2) ? And hence there is not equivalence?
Yep that's right.
The statement "[itex]a^2 = c[/itex]" however is equivalent to the statement "[itex]a = \sqrt{c} \textbf{ or } a = -\sqrt{c}[/itex]".
.......we can prove that...........
.....for all a,b [ a>=b & a<=b <=======> a=b]..........
so you do not have to define it
What do you mean by "a = b" ?
I assume it means "a if and only if b".
I don't like this notation, because it allows for statements like
1 = 2 = 3 = 4.
1 = 2 = 3 = 4.
HOW does it allow for that? What does "1 if and only if 2" mean?
That's what I mean. The first and last "=" are ordinary equality symbols (if you insist on abstractness: it may be equality in first order logic, in which 1, 2, 3 and 4 are constants). The second "=" is then the equivalence symbol (meaning that the expression (1 = 2) takes the same truth value as (3 = 4)).
If I am following the post correctly, a >= b b >= a <=> a = b is not correct since the second statement does not imply the first.
But the first statement does imply the second.
By the way, the notation ">=" instead of "=>" also suggests you are not talking about implication ([itex]\Rightarrow[/itex]) but about inequality ([itex]\ge[/itex]) here, in which case you are right. :smile:
This may get confusing.
......thanks compuChip...........
Here you are:
a=b====> a>=b & a=b=====> b>=a hence a=b ====> a>=b & b>=a
  • · Replies 22 ·
  • · Replies 30 ·
  • · Replies 18 ·
  • · Replies 18 ·
