Markov chain calibration to a set of cumulated frequencies.
The problem involves calibrating a transition matrix for a Markov chain representing a population of firms that can exist in three states: good, bad, and default (bankrupt). The task is to find a transition matrix based on given cumulative frequencies of defaults over a period of years.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the need to minimize the difference between the transition matrix raised to the power of n and the provided cumulative frequencies of defaults. There is a suggestion to use least squares for approximation, but uncertainty exists regarding the setup of the problem and the nature of the objective function.
Some participants are attempting to clarify the mathematical framing of the problem, while others are exploring the implications of the absorbing state in the transition matrix. There is an ongoing exploration of whether the minimization should be approached symbolically or through regression methods.
Constraints include that the first two rows of the transition matrix must sum to 1, and the last row must reflect the absorbing state of default. The discussion also notes the availability of cumulative frequency data for multiple years.
ibimbo
Hi!
I have been given such a task:
A population of firms can assume three states: good-bad-bankrupt (default)
The cumulated frequencies of default (DP) from year 1 to 10 are given.
Find an appropriate transition matrix (TM)
I'm given a matrix of historical cumulated frequencies of default like this:
DP =
firm type/year
1 2 3 and so on
good 0.7 0.5 0.3
bad 0.8 0.6 0.4
and i have to find a transition matrix which looks like the following
TM=
good bad default
good ? ? ?
bad ? ? ?
default 0 0 1
TM^n
gives the transition matrix from year 1 to n, and specifically the column "default" will show the cumulative frequencies of defaults in year n.
Basically i have to minimize the difference between the defaults column of the TM and the cumulated frequencies (DP) i am given for TM^n, with n from 1 to 10 years, therefore i have 10 equations like
Min --> TM^n(last column)-DP(n)
Constraints:
- 1st and 2nd row have to sum to 1
- last row has to be 0,0,1
I would appreciate if someone could help me to frame this problem ;)
Hint: i read on a paper that was doing that exercise they used "least squares", but in my studies i have never gone beyond fitting a time series, while here i have a matrix annd i am completely lost :(
Hi, anyone? :(
If you want help, you'll have to frame it in mathematical terms. Let me try and understand. You have a list of probabilities for a firm to default, one vector for each year, D(n), given a firm's state in year 1. You want to find the 3x3 transition matrix, T, such that a firm in default stays in default with probability 1 and that after n years the probability that a firm will go into default is as close as possible to the given probabilities for that year, i.e. T^n - D(n) is minimal.
Is the problem asking for an exact, symbolic minimization or some sort of regression, best fit algorithmic approach?
hi thanks for helping out!
The Default state is absorbing, meaning the prob for a defaulted firm to become good or bad is 0, hence the last row of my transition matrix is [0,0,1].
I was told to find an approximation method, suggesting least squares.
However i would not know how to set up the problem, as in my studies i have just come across rather simple OLS or linear programming problems, while this is a bit more complicated, because the objective function doesn't look any linear.
Unknown: Transition Matrix (T)
Problem: Min(T^n-D(n))
-by T^n i mean the last column which contains the probabilities to migrate to Default State.
- D(n) data is available for n=1 to 40
sub
- T(Good,Good)+T(Good,Bad)+T(Good,Default)=1
- T(Bad,Good)+T(Bad,Bad)+T(Bad,Default)=1
- T(Default,Default)=1 T(Default,Good)=0 T(Default,Bad)=0
