I can not assume the sense of the friction force?
The discussion centers on the challenges of determining the direction of friction force in statics problems, particularly when using the equation F = uN. Unlike other mechanical forces, the direction of friction is dependent on the motion of the object; if an object is assumed to slide to the right, the friction force must act to the left. The participants emphasize that the equation F = uN is not a vector equation, as the normal force and frictional force are typically perpendicular, complicating the assumption of direction.
  • Understanding of static equilibrium principles
  • Familiarity with the equation of friction F = uN
  • Knowledge of vector forces and their components
  • Basic mechanics concepts, including normal force
  • Study the principles of static equilibrium in mechanics
  • Explore vector analysis in physics, focusing on force components
  • Learn about the implications of friction in different motion scenarios
  • Examine case studies involving friction force direction in statics problems
Students and professionals in mechanical engineering, physics educators, and anyone involved in analyzing static systems and friction forces.
hyper
With all the mechanical forces in statics problems I can assume the sense and I might get a negative answer which implies I made the wrong assumption. But why can I not do this with the friction force when using the equation F=uN?
Because the direction of friction is not independent of other variables. For example, if you assume something slides to the right, then friction on it must point left.
Perhaps discussing a specific example would help, if you have one.
Besides, the equation you mention is not a vector equation, so you can't use it to find direction. It can't be a vector equation, because in ordinary cases the normal force and frictional force are perpendicular.
  • · Replies 59 ·
  • · Replies 35 ·
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 25 ·
