Limit & Continuity of f(x) = sqrt(x+3), -3 < x < -1
  • Thread starter Thread starter fr33pl4gu3
    Continuity Limit
The discussion revolves around evaluating limits for the piecewise function f(x) = sqrt(x+3) for x > -3 and 3x^2 - 5 for x < -3, specifically as x approaches -3 from both sides. Participants are exploring the continuity and limit behavior of the function at this point.
  • Participants discuss the limits as x approaches -3 from the left and right, questioning the values obtained and the reasoning behind them. There is confusion regarding the correct evaluation of these limits and the continuity of the piecewise function.
Some participants have provided guidance on how to approach the limits from both sides, while others express uncertainty about their calculations and the reasoning behind their answers. There is an ongoing exploration of the values obtained and the conditions under which the limits exist.
Participants note that the limits must be equal for the overall limit to exist, and there is mention of a quiz system that indicates incorrect answers, adding pressure to resolve the discrepancies in understanding.
fr33pl4gu3
f(x) = sqrt(x+3), x > -3
3 x2-5, x < -3
first question would be limit x -> -3-, limit x -> -3+, limit x -> -3
the answer would be [-1, 1, undefined]
But, i only got the 3rd answer correct, the first two are wrong?? but i don't get it why, the previous similar question, i got it correct, but here i got it wrong??
When you are being asked for [tex]\lim_{x \rightarrow -3^{-}[/tex] that means you are approaching -3 from the left side so look at which part of your f deals with the values "to the left" of -3 i.e. -4, -3.5, -3.1, -3.01, ..., -3.0000001, ... That part should be [tex]3x^{2} - 5[/tex] and the values I'm getting are 43, 31.75, 23.83, 22. Similarly for [tex]\lim_{x \rightarrow -3^{+}[/tex] you deal with values "to the right" of -3 which you would use [tex]\sqrt{x+3}[/tex] so once again pick values like -2, -2.5, -2.9, ..., -2.99999, -2.99999999999999 you should get 1, .707107, .003162, 0.0000001. Does that make sense? The reasons why you got the 3rd part correct is because for the limit to exist, you need to have the limit be the same regardless of which side you approach from which is obviously not the case here.
Hi fr33pl4gu3! :smile:
Why did you think lim sqrt(x+3) as x -> -3+ was 1? :confused:
If we know that, then we can help you. :smile:
so the answer should be 43, 1, undefined, correct??
Are you using -4 instead of -3? :confused:
Always show us your full calculation, not just your answer, if you want us to understand where you're going wrong. :smile:
Does both of the final answer has to be equal??
How do you get 43? As I said, for the limit to exist, you must get the same answer if you approach from the right hand side and left hand side.
lhs = 3(-4)2-5=43;
rhs = sqrt(1846+3)=43;
correct??
fr33pl4gu3 said:
lhs = -4;
rhs = 1846;
correct??
Did you read my post where I pretty much solved the problem for you?
yes, i did try, but this question is a quiz system, so it say is incorrect, so i have no idea too, i use 43 just like you said, lhs = x = -4, rhs = x = 1846.
Why are you all of a sudden using 4? Wasn't your original question to have x approaching 3 from both sides?
Yep, thanks, i solve it, type wrongly, supposed to be typing the final answer but i always type the value of x, so sorry.
3 x2-5, x < -3
Since 3x2- 5 is a continuous function, the limit, as x goes to -3 from below is just 3(-3)2- 5 which is definitely NOT -1.
Since [itex]\sqrt{x+ 3}[/itex] is a continuous function for [itex]x\ge -3[/itex] The limit as x goes to -3 from above is just [itex]\sqrt{-3+3}[/itex] which is NOT 1.
Since you have shown no work at all, I have no idea how you got those answers.
(And since this has nothing at all to do with differential equations, I am moving it to the "Calculus and Beyond" homework section.)
"Just like you said"? No one but you has mentioned "43"!
Yes they did :smile::​
NoMoreExams said:
…and the values I'm getting are 43 …
Ohh I see how he got 43 now. Thanks tiny-tim. In my effort to show him what it means to approach from different sides, he took it to mean something completely different.
  • · Replies 27 ·
