How Do You Calculate the Mass of a Block of Ice Using Thermal Dynamics?
  • Thread starter Thread starter derfrok
    Dynamic Thermal
The mass of a one cubic foot block of ice can be calculated using thermal dynamics principles. It takes 333,465 Joules of energy to convert 1 kg of solid ice into liquid water at 0 degrees Celsius. Given the density of ice at approximately 917 kg/m³, the mass can be determined using the formula M = 333,465 J / (2000 J/kg-C x 20°C), resulting in a mass of approximately 8.336 kg for the block of ice. This calculation incorporates the specific heat of ice and the energy required for melting.
  • Understanding of thermal dynamics principles
  • Knowledge of specific heat capacity (2000 J/kg-C for ice)
  • Familiarity with energy conversion (Joules)
  • Basic understanding of density (917 kg/m³ for ice)
  • Research the concept of specific heat and its applications in thermal dynamics
  • Learn about the properties of ice and its phase changes
  • Explore the calculations involved in energy transfer during phase changes
  • Investigate the implications of thermal dynamics in real-world scenarios, such as climate science
Students studying physics, engineers working with thermal systems, and anyone interested in the principles of energy transfer and phase changes in materials.
derfrok
Ok, I don't quite understand the concept of thermal dynamics. So, I need some help here.
When ice melts it takes 333,465 Joules of energy to convert one 1KG of solid ice into liquid water at 0 degrees celsius. Suppose that you have a one cubic foot block of ice.
I need to find the MASS. Can someone please point me in the right direction? :biggrin:
Here's what i got so far:
333,465j=M*2000j/kg-celsius(0-20)?
I presume the question is to find out how much energy is needed to melt that much ice at 0 degrees? If so, look up the density of ice in order to find the mass of this block. (I think it's something like 917 kg/m^3.)
Sure, I'd be happy to help with some thermal dynamics! First, let's break down the information given. Thermal dynamics is the study of how heat and energy transfer and transform in a system. In this case, we are looking at the specific heat of ice, which is the amount of energy needed to raise the temperature of one kilogram of ice by one degree Celsius. This value is 2000 joules per kilogram per degree Celsius.
Now, let's apply this information to the given scenario. We know that 333,465 joules of energy is needed to melt one kilogram of ice at 0 degrees Celsius. So, we can set up an equation:
333,465 joules = M (mass of ice) x 2000 joules/kg-C x (0-20 degrees Celsius)
Solving for M, we get:
M = 333,465 joules / (2000 joules/kg-C x 20 degrees Celsius) = 8.336 kg
Therefore, the mass of the ice cube is approximately 8.336 kilograms.
I hope this helps! Let me know if you have any other questions or need further clarification. Keep up the good work!
  • · Replies 17 ·
  • · Replies 25 ·
  • · Replies 33 ·
