A number of 10 digits is build up in the following way
  • Context: Undergrad
  • Thread starter Thread starter dirk_mec1
    Build
The discussion revolves around a mathematical problem involving the construction of a 10-digit number where each digit from 0 to 9 is used exactly once, and specific divisibility conditions must be satisfied by the number formed by the digits. The participants explore various approaches to determine the digits based on these conditions, including reasoning about divisibility and the implications of digit placement.
  • One participant suggests that the last digit must be 0 and the fifth digit must be 5, questioning how to find the remaining digits.
  • Another participant agrees that the tenth digit is 0 and notes that the ninth digit must be 9, but challenges the earlier reasoning about the first nine digits needing to be divisible by 9.
  • Further clarification is provided that not only must the sum of the first nine digits be divisible by 9, but also various combinations of digits must satisfy additional divisibility rules, such as sets of three digits being divisible by 3 and pairs being divisible by 2 and 4.
  • There is a discussion about the even digits needing to be in specific positions, with some participants proposing that a4 and a8 must be 2 or 6 due to the odd nature of a3 and a7.
  • One participant interprets the problem differently, suggesting that the fragments of the number must satisfy the divisibility requirements, leading to a computational approach to find possible solutions.
  • This participant reports finding 202 possible answers under their interpretation, contrasting with the common interpretation which yielded no solutions.
Participants express differing interpretations of the problem and its requirements, leading to multiple competing views on how to approach the solution. There is no consensus on the correct method or the number of valid solutions.
Some assumptions about the placement and divisibility of digits remain unresolved, and the discussion highlights the complexity of the problem without arriving at a definitive solution.
dirk_mec1
A number of 10 digits is build up in the following way:
The first digit is divisible by one.
The first two digits are divisible by two.
The first three digits are divisible by three.
What is the number if 0,1,...,10 can only be used once?
I can reason that the last digit is 0 and the fifth is 5. How can I find the other ones?
The tenth digit is divisible by 10, so it must be 0. The ninth digit must be divisible by 9, so it must be 9 or 0, but 0 is taken. This should give the answer readily.
No! The first nine digits are divisible by nine. So this tells us (a1+a2+...+a9)|9.
That is true, but also every set a1+a2+a3 and a4+5 + a6 , and a7+a8 +a9 must be divisible by 3, every even digit is divisible by 2 the set a3 a4 is divisible by 4 and the set a6,a7,a8 is divisible by 8 and a1a2a3a4a5a6a7 is divisible by 7. That is all the information you need. It figures that both a4 and a8 must be a 2 or 6 since a3 and a7 are odd. Therefore a2 and a6 are each divisible by 4.
a4 and a8 can be 2,4,6 or 8 right? So if I understand correctly this becomes an integer programming problem?
That is not what I said. "a4 and a8 must be a 2 or 6 since a3 and a7 are odd" This is because a2,a4,a6 and a8 must each be even so there is no even number left to fit in a3/a7. It is a simple logic problem but you have to try looking at possibilities one at a time. If A8 is a 6 then A7 must be a 9 or 1 to make a6a7a8 divisible by 8 If A7 is a 9 then A9 must be a 3 to make a7+a8+a9 divisible by 3. Also from what I said earlier A4 must be a 2 and a6 must be a 8 to make a4+a5+a6 divisible by 3. This leaves only an 4 to fit in a2. You keep trying possibilities but logic helps speed up the process by narrowing the options. If you run out of possibilities first then you backtrack until you can try a different option that wasn't tried before.
I read this problem in a different way, that fragments of the number had to satisfy the divisibility requirements. For example, take a ten digit number like 9654873120, where each digit is only used once. Note that 0 is divisible by one, and 20 is divisible by two. 120 is divisible by three, and 3120 is divisible by four. 73120 is divisible by 5, 873120 is divisible by six, 4873120 is divisible by seven, etc.
It was easy to show from the constraints that the rightmost digit had to be zero, that the next digit had to be even, and even that the leftmost digit had to be a nine. Beyond that, there seemed like a lot of variation was possible, since the criteria mainly affected the least significant digits. For example, the four digit fragment being divisible by 4 only affected the rightmost two digits, and the eight digit fragment being divisible by eight only affects the rightmost three digits, etc. So it seemed time for a little program to see if there were any solutions of the problem stated this way.
For a ten digit sequence, I was a bit surprised to find there were 202 possible answers. I has expected either many more or much fewer. That would have been more aesthetic, but the universe seems to enjoy disregarding my notions of how it should behave. Good thing too, I suppose.I just modified the program to check the problem as it seems to have been commonly interpreted, that the sum of the rightmost digits must be divisible by the number of digits, and for that there are no solutions.
  • · Replies 17 ·
  • · Replies 33 ·
  • · Replies 0 ·
