How Is Tension Calculated in a Pendulum with Varying Angles?
  • Thread starter Thread starter devanlevin
    Mass Pendulum
The discussion revolves around calculating the tension in a pendulum system where a mass is suspended from a ceiling by a cord of length L and swings at varying angles, specifically at a maximum angle of "alpha max." Participants are exploring how to express the tension T in terms of the mass m, gravitational acceleration g, the angle alpha, and the length L.
  • Participants are attempting to derive an expression for tension T using the principles of circular motion and energy conservation. There are discussions about the relationship between tension, radial acceleration, and potential energy at different angles.
The discussion includes various attempts to manipulate equations to express T in the desired form. Some participants question the necessity of including the length L in their final expression, while others are exploring the implications of maximum angle on the calculations. There is no explicit consensus on the correctness of the derived expressions, and multiple interpretations are being examined.
Participants are working under the assumption that there is no friction and that energy is conserved throughout the motion of the pendulum. There are also references to specific parameters that need to be included in the final expression for tension.
devanlevin
how can i express tension in this case, using alpha, alpha max,g, m, and L ??
a case of a mass of m hanging from a ceiling on a cord with a length of L swinging at a maximum angle of "alpha max" on either side, and at any given moment and an angle of alpha(changes all the time)
how can i express T, the strings tension, using the parameters m,g,alpha,alpha max,and L??
what i did was say:
according to circular movement, looking at the radial acceleration ar
F=ma
T-mg*cos(alpha)=mar=m*v^2/L
T=m(v^2/L+g*cos(alpha))
now how can i express v using the parameters, what i think i need to do is look at the maximum angle, and say V=0 so mar=0 so T(point of max)=mgcos(alpha max) but i don't see how that cann further me at all,
again, in the end i need an expression T=? using only m,g,L,alph, alpha max
***no friction at all, mass will reach alpha max every time, no loss of energy
T-mg*cos(alpha)=(m/L)*v^2
V^2=(L/m)(T-mgcos(alpha))
from here using energy,
E(max point)=mgh=const
my point of reference for potential energy being the ceiling
h=cos(alpha)*L
E=0.5mv^2+mgh=-mgcos(alpha max)*L
v^2=(L/m)(T-mgcos(alpha))
0.5(m)(L/m)(T-mgcos(alpha))-mgcos(alpha)*L=-mgcos(alpha)*L
0.5(T-mgcos(alpha))-mgcos(alpha)=-mgcos(alpha)
T-mgcos(alpha)-2mgcos(alpha)=-2mgcos(alpha)
T=3mgcos(alpha)-2mgcos(alpha max)
is this correct??
the question asked me to use L in the expression, do i need it??
I would start by determining the period of the pendulum which will be a function of length and gravity. You then have your alpha max which will determine your displacement. Period and displacement you can then equate to velocity.
EDIT: Bit of a time lapse with post #2, wasn't able to read it before this post. What happened to this L?
i divided the whole equation by L
  • · Replies 26 ·
  • · Replies 20 ·
