Maximizing TNT Production from Toluene: A Chemical Problem Solved
  • Thread starter Thread starter ignorant1
    Hard
The discussion focuses on the production of trinitrotoluene (TNT) from toluene using nitric acid as a reagent. The chemical reaction is represented as C7H8 + 3 HNO3 → C7H5N3O6 + 3 H2O. To calculate the amount of TNT produced from 46 kegs of toluene, participants clarify that the measurement should be in kilograms, not kegs. The process involves determining the number of moles of toluene by dividing its mass by its molar mass and then converting the moles of TNT back to kilograms using its molar mass.
  • Chemical reaction balancing
  • Molar mass calculations
  • Stoichiometry in chemical processes
  • Understanding of explosive chemistry
  • Research the molar mass of toluene (C7H8) and TNT (C7H5N3O6)
  • Study stoichiometric calculations in chemical reactions
  • Learn about the properties and handling of nitric acid in chemical synthesis
  • Explore safety protocols for working with explosives in a laboratory setting
Chemistry students, chemical engineers, and professionals involved in explosive material production will benefit from this discussion.
ignorant1
so easy, and yet so hard...
I have a really easy problem in my chemistry class, bot somehow, i can't seem to come out with the right answer... well, here it is...(by the way, i don't know how to write out the sub-scripts...)
Nitric acid is used in the production of trintrolune (tnt), an explosive.
C7 H8 +3 HNO3 ---->C7 H5 N3 06 + 3 H2O
tolune TNT
How much TNT can be made from 46 kegs of toluene?
:confused: =me
Normally, only [tex]C_2H_5OH[/tex] comes measured in kegs (of course, it's normally diluted by some other indredients when it comes by the keg). Do you mean kilograms?
If so, you need to divide the mass by the molar mass of your substance to find out how many moles of [tex]C_7H_8[/tex] you have (since nitric acid is cheap, you can add however much you need).
I imagine your answer is supposed to be measured in kilograms, as well. Same as the first, but in the opposite direction. Multiply the number of moles of TNT by the molar mass.
thanks!
thanks, that really helps! :biggrin:
