Aircraft drops package find vertical distance
  • Thread starter Thread starter qwerty3
    Aircraft Vertical
The discussion revolves around a physics problem involving an aircraft dropping a package subject to air resistance. The problem requires understanding the forces acting on the package, including gravity and drag, and involves deriving equations for vertical and horizontal distances traveled over time.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the implications of different assumptions regarding the direction of forces and the sign of the drag coefficient k. There are discussions about the correct setup of force equations and the treatment of initial conditions.
Participants are actively engaging with the problem, questioning the signs used in their equations and the interpretation of drag force. Some have suggested starting from fundamental force equations, while others are sharing their attempts to derive the equations of motion. There is no clear consensus yet, but various approaches are being explored.
There are indications of confusion regarding the treatment of forces based on the chosen coordinate system, particularly whether to consider upward or downward as positive. This has led to differing interpretations of the drag force's direction and its impact on the equations being derived.
qwerty3
An aircraft flying in a straight line at constant height h and speed U drops a package
on a target at ground level. The package is subject to air resistance whose magnitude
is kmv where v is the speed of the falling package, m its mass, and k > 0 a constant.
(a) Show that the vertical distance that the package falls in time t is
V(V/g(e^(-gt/V)-1)+t)
where V is the terminal velocity of the package, and find the horizontal distance
travelled in the same time t.
(b) Find the cartesian equation for the path of the falling package.
Hi i want to know what my constant k is??
when i use k=-g/V i get the wrong answer, but when i use k=g/V i get the negative of what they want:S:S
please help
I think you should not start off by trying to impose an expression for k. (You can see what the dimensions should be, but we don't know what might crop up dimensionlessly...)
Perhaps you should start with the two force equations, since this is a ballistics problem with air drag:
[tex]ma_x = -kmv_x[/tex]
and
[tex]ma_y = mg - kmv_y[/tex]
subject to the stated initial conditions
[ v_x(0) = U , v_y(0) = 0 , y(0) = 0, and call x(0) = 0 ]
and calling "downward" positive.
Well i took upwards as positive and so my mg is -mg.
Since you haven't shown the work you did, it is somewhat hard to judge why you aren't getting your signs to come out right. I suspect that you have not handled the differential equations and the initial conditions consistently in terms of signs.
ok i will show it its just that its hard to type it all up
Total force = -mgj -kmv
Newtons 2nd law a = -gj -kv => a + kv = -gj
Try integrating factor e^(int kdt)= e^(kt)
d/dt (e^kt v) = -ge^kt j
e^kt v = -g/k e^kt j + C
t=0 v=u => C = u + g/k j
v = (u + g/k j)e^-kt - g/k j
v=dr/dt
r = -1/k (u + g/k j) e^-kt - g/k tj + C'
r=0 t=0 => C' = 1/k (u + g/k j)
r = -1/k (u + g/k j) e^-kt - g/k tj + 1/k (u + g/k j)
r = (g/k^2 j + u/k)(1 - e^-kt) - g/k tj
u=ui as only horizotal speed
x(t) = u/k (1 - e^-kt)
y(t) = g/k^2 (1-e^-kt) -g/k t
and then when i work out what k is i don't get the answer as i get k=-g/V
Ah, but there's a problem right here. If upward is positive and the object is falling, then with the weight force being downward and the drag force upward, this needs to be
[tex]ma_y = -mg + kmv_y[/tex]
or just [tex]\frac{dv_y}{dt} = -g + kv_y[/tex]
(Oh, and if you're going to write in unit vectors -- which isn't really necessary -- be sure to put them in across the board.)
The choice of axis makes things awkward, in that you must interpret vy as negative throughout your solution. If you write the "correct" force equation, k must also be negative. If you use the equation you've written, k will be positive, but the velocity must still be treated as negative.
It really makes for less of a headache to call downward positive and work with
[tex]\frac{dv_y}{dt} = g - kv_y[/tex]
but it should work either way if you treat all the signs of quantities consistently.
BTW, an integrating factor will work, but you could just solve this as a separable differential equation.
Actually what i want to know is that my way with vectors how do i split up the x and y component as with y the kmv is +ve
qwerty3 said:
i don't really get why the drag force is upwards please explain
Drag force retards speed. Gravity is accelerating speed. Whichever convention for direction you use, your equation should reflect that they have opposite signs.
Not sure what you mean by "ve", but your x component of velocity comes from the initial speed of the plane. But of course that velocity slows as the package encounters the drag. Note that drag is proportional to velocity so as it slows the drag becomes less until it approaches zero as velocity approaches zero - in the x direction only.
The trajectory then is the combination of the x/y position equations as a function of time.
its ok thanks i get it now and +ve means positive :P sorry for the confusion
  • · Replies 38 ·
  • · Replies 25 ·
