Increasing Red Light Intensity Without Color Change
To achieve a higher intensity red light without altering its color, several methods are recommended. Running multiple filaments at lower current can enhance brightness while maintaining the red hue. Alternatives include using gas-filled bulbs like helium or purchasing infrared bulbs, which emit a high-intensity red light. Additionally, colored LED and fluorescent bulbs are viable options available in hardware stores.
  • Understanding of light bulb technology and filament operation
  • Knowledge of gas-filled bulbs and their properties
  • Familiarity with LED and fluorescent lighting options
  • Basic principles of color theory in lighting
  • Research the specifications and applications of infrared bulbs
  • Explore the properties and uses of gas-filled bulbs like helium and neon
  • Learn about the manufacturing process of colored LED and fluorescent bulbs
  • Investigate the effects of filament arrangement on light intensity
Lighting designers, electrical engineers, and hobbyists interested in optimizing light bulb performance and color intensity.
raybuzz
Hi everyone,
In a light bulb, as we increase the temperature of the light bulb, the colour produced by the light bulb changes from red to blue ( intensity vs frequency curve shifts to the left).
But if i want to have a red bulb with higher intensity ( i.e. brighter red) without the colour being changed what do i do?
Run the filaments at lower current, but more of them.
Dye the bulb red.
Use a gas in the bulb that glows red (or do you want orange?) Have you seen those flickering candle bulbs? I don't know how it's done.
Edit: In reconsidering, at a guess, you don't want to make or modify your own light bulb. Perhaps you could try to series two 120VAC bulbs and get a nice orange glow out of them.
raybuzz said:
Hi everyone,
Spend the extra money and buy the infrared bulb? They have a pretty high-intensity red, but this might be a little too far to the red for your liking (considering they're meant to be used to keep food hot), and they're really expensive.
You could also go with non-blackbody gas-filled bulbs which radiate at a single (or a few) frequencies. Helium, maybe? Neon signs use phosphors to change the UV part of the emission to whatever the desired light is.
I've also seen colored LED and fluorescent light bulbs in hardware stores around town, though I've never been able to justify purchasing any.
  • · Replies 20 ·
  • · Replies 207 ·
16K
  • · Replies 40 ·
