Faraday Cage Concept and Building Questions
The discussion centers on the construction and functionality of Faraday Cages, emphasizing that the mesh must have holes smaller than one-tenth of the wavelength intended to be blocked. Materials such as copper and steel enhance conductivity, with thicker wires and smaller holes improving isolation. Mylar and foil function effectively as Faraday devices due to their conductive layers reflecting electromagnetic (EM) energy. Grounding is not necessary for protection against electromagnetic pulses (EMPs) or lightning strikes, as the charge flows over the cage's exterior.
  • Understanding of electromagnetic waves and their wavelengths
  • Knowledge of materials' conductivity, specifically copper and steel
  • Familiarity with the concept of electromagnetic pulses (EMPs)
  • Basic principles of electrical grounding
  • Research the construction of effective Faraday Cages using various materials
  • Study the properties of electromagnetic waves and their interaction with conductive materials
  • Learn about the effects of EMPs on electronic devices and protective measures
  • Explore grounding techniques and their relevance in electrical safety
Electronics engineers, hobbyists building protective devices, and anyone interested in safeguarding equipment from electromagnetic interference.
kandrey89
I have a few questions and verifying statements regarding the concept as well as practical building of Faraday Cages.
1. A Faraday cage's mesh must have a grid with a spacing less than that of the wavelength that is intended to be stopped.
2. Why is it that foil and mylar also work as faraday cage devices when wrapped around an object, I saw this on quite a few websites and don't understand how this works with the Faraday Cage concept.
3. Does the material used ie. copper, steel, ... or the diameter of the rods that make up the cage's mesh matter, are certain materials better, do diameter of rods matter in practical applications or the size of the rod doesn't matter (begs the question regarding wavelength size because a 10 inch rod mesh would not be able to stop radio wavelength... right?)?
4. What is the harmful to electronics EM spectrum that is emitted by a nuclear bomb? This should hopefully identify what wavelength the equipment should be protected against.
5. Must a Faraday Cage be grounded when working against an EMP? Musr a Faraday Cage be grounded when working against a lightning bolt\or Van de Graff generator?
Thank You
No. It needs a mesh with holes smaller than about one tenth of a wavelength. But even those will not stop all energy. Any hole will allow some energy to pass through. Currents flowing on the outer surface of the cage will cause a current to flow along the edge of the hole. That edge current will direct some energy into the cage.
The Mylar has no effect on the waves. Mylar coated with a metal film, or a foil can act as a screen since the conductive layer makes a mirror that reflects EM energy.
The more conductive the metal the better the reflection. Thicker wires and smaller holes increase the effective conductivity, so improve the isolation.
The Electro-Magnetic Pulse, EMP, radiated by a nuclear bomb is a fast step that contains all frequencies. Equipment must be protected against all wavelengths, from DC to gamma rays. Any exposed semiconductors will be destroyed.
No, it does not need to be grounded. The strike will flow over the outside of the cage. There will be little charge inside the container.
15K
  • · Replies 20 ·
18K
  • · Replies 19 ·
13K
  • · Replies 29 ·
