Eqn of Plane passing through a point and perpendicular to another plane's trace
The discussion centers on finding the equation of a plane that passes through the point (-3,1,4) and is perpendicular to the trace of the plane defined by the equation x-3y+7z-3=0 in the xy-plane. The correct approach involves identifying the trace of the given plane in the xy-plane, which is represented by the equation x-3y-3=0, leading to a direction vector of <3, 1, 0>. The normal vector of the desired plane is thus <3, 1, 0>, resulting in the equation 3x + y + 8 = 0, which differs from the initial incorrect calculations that led to 4x - 12y + 9z - 3 = 0.
  • Understanding of plane equations in 3D space
  • Familiarity with vector operations and normal vectors
  • Knowledge of parametric equations
  • Ability to manipulate algebraic equations
  • Study the derivation of plane equations from normal vectors
  • Learn about parametric equations of lines and their applications in 3D geometry
  • Explore vector algebra, specifically focusing on cross products and dot products
  • Review examples of finding equations of planes given points and direction vectors
Students studying geometry, particularly those focusing on 3D space and plane equations, as well as educators seeking to clarify concepts related to vector mathematics and algebraic manipulation.
Stumbleinn
Here's the problem:Find the equation of the plane passing through the point (-3,1,4) and perpendicular to the trace of the plane x-3y+7z-3=0 in the xy plane.
to me this should be as easy as finding the two coordiates of the plane's traces on the x and y axis. ie (3,0,0) and (0,-1, 0). Since these two points and the point (-3,1,4) determine the plane.
since the general form of the plane is Ax+By+Cz+D=0. I should get 3 equations that look like this:
1) 3A+D=0
2) -B+D=0
3) -3A+B+4C+D=0
1) implies that -D/A=3 and thus D=-3 and A=1
substituting into eqn2 yields B=-3
and sunstituing into eqn3 gives C=9/4
so the eqn should be x-3y+9/4Z-3=0 or 4x-12y+9z-3=0
However the answer in the book is 3x+y+8=0. I find that the book is rarely wrong and usually it's me that is confused.
Please advise on where I went wrong
Thanks so much
These 3 points give the plane containing the trace in the xy plane, not perpendicular to it. The trace of the plane in the xy-plane is given, of course, by x- 3y- 3= 0 and z= 0. If you use y itself as parameter, x= 3y+ 2, y= y, z= 0 are parametric equation of that line. A vector pointing in the direction of that line is <3, 1, 0>. You want the equation of a plane containing (-3, 1, 4) and having normal vector <3, 1, 0>.
1) 3A+D=0
2) -B+D=0
3) -3A+B+4C+D=0
Thanks so much
