The Influence of Distance on Torque in Rotating Systems
  • Thread starter Thread starter chandran
    Shaft Wheel
The discussion centers on the influence of distance between the pivot point (point A) and the point of torque application (point B) in rotating systems. It is established that the torque applied to the wheel is directly affected by this distance, as torque is calculated by the formula τ = r × F, where τ is torque, r is the distance from the pivot to the point of force application, and F is the applied force. The conversation highlights the importance of understanding how torque is applied in relation to the wheel's position on the shaft.
  • Understanding of basic physics concepts, specifically torque and rotational motion.
  • Familiarity with the formula for torque (τ = r × F).
  • Knowledge of mechanical systems involving shafts and wheels.
  • Basic grasp of pivot points and their role in rotational dynamics.
  • Research the principles of torque in mechanical engineering.
  • Explore the effects of distance on torque in various rotating systems.
  • Learn about the applications of torque in real-world mechanical devices.
  • Investigate the role of pivot points in enhancing or reducing torque efficiency.
Mechanical engineers, physics students, and anyone interested in the dynamics of rotating systems and torque application.
chandran
there is a wheel. A shaft which rotates about a pivot point a is connected to the wheel
at the point b. what is the influence of the distance a to b in the torque applied to the wheel . the wheel just rests on the shaft at point a and it is not welded to the shaft.
Didnt get your question,how exactly are you applying the torque?
  • · Replies 25 ·
  • · Replies 35 ·
  • · Replies 30 ·
  • · Replies 32 ·
  • · Replies 39 ·
