| Thread Closed |
Confused about Ferrite Beads |
Share Thread | Thread Tools |
| Aug26-08, 09:20 AM | #1 |
I'm currently looking at a datasheet for ferrite-bead style inductors, specifically, http://search.murata.co.jp/Ceramy/Ca...ram=blm31aj601 . I understand that its impedance changes as a function of frequency and it is primarily used to combat EMI, but how would I determine the inductance value of said inductor? Or is that a parameter that is not normally given on this style of inductor? I know I could set up a test circuit and measure it experimentally, but that's not really an option at this point.
Thanks for the help! |
| Aug26-08, 09:25 AM | #2 |
Actually...now that I think about it a little more, wouldn't I just be able to solve Z=sqrt(r^2 wL^2) and get the inductance that way?
Edit- No, probably not, because I don't have the purly resistive value. Hmpf. |
| Aug26-08, 10:11 AM | #3 |
When I was working to pass some equipment through sec.15 in the FCC regulations, I discovered quite quickly that the math varied from reality.
The design parameters suggested a value but from the actual testing a sometimes very different value turned out to produce the lowest RF leakage. The design team would scratch their heads at the data and try to recalculate the values, but the test values were inevitably used in production. Fun times. |
| Aug26-08, 11:02 AM | #4 |
Mentor
Confused about Ferrite BeadsSo, special materials are used for EMI supression beads, like material 43 for example. The material is lossy at RF frequencies (so it would make a lousy inductor, BTW), so what you see on the impedance analyzer is a rising impedance with frequency up to about where resonance would be, and then the impedance flattens out for a broad RF frequency range after that before falling off. The "impedance" or "resistance" spec for the EMI beads is usually the value of that flat spot in impedance, with a test frequency specified. Check out the Fair-Rite website for more info on EMI supression beads and materials: http://www.fair-rite.com/newfair/index.htm . |
| Aug26-08, 11:12 AM | #5 |
Thanks! So, in terms of a circuit experiencing resonance, would this mean that there is a wider band of frequencies that will cause resonant behavior than if we used a standard inductor?
| Aug26-08, 11:37 AM | #6 |
Mentor
Look at the relatively wide bandwidth of impedance for some of these beads: http://www.fair-rite.com/newfair/pdf/CUP%20Paper.pdf You don't use EMI supression beads in resonant circuits. You use them as RF impedances to block or divide down RF energy, while still passing your lower-frequency signal energy (like in datacom). |
| Aug26-08, 11:41 AM | #7 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Confused about Ferrite Beads
| ferrite beads block cell phone radiation? | Computing & Technology | 9 | ||
| How do ferrite beads work? | General Physics | 1 | ||
| Usage of chip ferrite beads | Electrical Engineering | 8 | ||
| Finding start of ferrite transformer | Electrical Engineering | 6 | ||
| RFID Antennas with ferrite Rod | Electrical Engineering | 0 | ||
