Collatz Conjecture Paper: Check it Out & Give Opinion
The discussion revolves around a paper related to the Collatz Conjecture, a longstanding mathematical problem. Participants are examining the paper's claims, potential errors, and implications for the conjecture, with a focus on its theoretical aspects and mathematical reasoning.
  • Some participants identify mistakes in the paper, such as the assumption that "the product 2y obviously takes the form 3n+1," which they argue implies all odd integers are 1 mod 6.
  • Concerns are raised about the clarity of the paper's writing, with some suggesting that the author may only be considering specific cases, such as when y is 5 mod 6.
  • Counterexamples are presented to challenge the claim that "each {x} is unique for each y," with y = 5 providing multiple x values (3, 13, 53, ...).
  • One participant argues that the author fails to demonstrate that every sequence ends in 1, as they only consider reverse sequences starting from 1.
  • Another participant mentions that Erdős believed the problem was not yet solvable and offered a reward for its proof, with some disagreement about the amount of the reward.
  • Discrepancies in calculations related to lower bounds for nontrivial cycles are discussed, with one participant claiming to have derived a significantly better lower bound than previously stated.
  • Some participants express uncertainty about the paper's validity, with one stating they found no errors after a revision, while another questions the clarity of the author's statements.
  • A mathematical argument is presented regarding the behavior of sequences under certain modular conditions, suggesting a convergence to 1, but this is presented with conditionality and assumptions.
Participants express a mix of opinions regarding the paper's validity, with some identifying errors and others defending its claims. There is no consensus on the correctness of the paper or the conclusions drawn from it.
Participants note limitations in the paper's clarity and the need for careful consideration of modular arithmetic in the context of the Collatz Conjecture. Some calculations and assumptions are debated without resolution.
phyti
The paper at this site "http://uts.awardspace.info" looked interesting to me, but would
anyone else familiar with this problem, it's been around since the 30's, check it out and give an opinion.
The first mistake I saw was on page 2: "The product 2y obviously takes the form 3n+1", which is tantamount (in this problem) to assuming that all odd integers are 1 mod 6.
The statement (also on p. 2) that "each {x} is unique for each y" has the obvious counterexample y = 5, for which x = 3, 13, 53, ... are possible. In fact finding counterexamples is easy because there are so many.
Wouldn't normally read such a paper, but as it's so short - here goes. First, a couple of comments on CRGreathouses comments above...
It's not very clearly written, so I can't be sure what he *really* means by many of his sentences. However, here I think he is only considering the case where y is 5 mod 6, so it looks right.
Yeah, that's just wrong. However, he never tries to use this (wrong) fact and it is clear that he knows you have to make a choice from an infinite set of possibilities.
In fact, he even shows that each term in such a sequence is 4 times its predecessor plus one.
I think he meant to say that y is unique for each x, which is obvious.
Looks like the main error in his reasoning is in the very last line.
All complete and incomplete reverse sequences can be formed using these sets.
Therefore all forward sequences will terminate with 1.
He only ever considers reverse sequences starting from 1. Clearly when you "un-reverse" such a sequence it will end in 1.
If he wanted to show that every sequence ends in 1, then he would need to show that every number appears in some reverse sequence starting from 1, which he never does.
I don't think so. That's the part in the paper in which the author assumes (*with* loss of generality) that 3n+1 is of the form 2^a * (6b + 1).
My friend has been working on this.. but I highly doubt he will make much progress in solving it.
Erdos did not think mathematics was ready for such problems. He also called it one of the few remaining problems which can readily explained to the layman. I think he offered a 50 dollar reward for its proof, which is still available through his estate.
Erdos offered $500. I though the prizes were being supported by Ron Graham rather than through the Erdos estate...?
I hope your friend bothers to read the literature on the problem before putting in too much work. For example, I see that Lagarias (1985, using a result due to Crandall and calculations due to Yoneda) showed a lower bound of 275,000 for the length of any nontrivial cycle.
I believe Lagarias was mistaken in his calculation, but on the conservative side. He used [itex]q_{13}=190737[/itex] instead of [itex]q_{13}=190537[/itex] but somehow managed to give 275,000 instead of 285,000 (even though the error should have gone in the other direction!).
Reworking the Crandall formula with Tomás Oliveira e Silva's calculations (no cycles up to 19 * 258) and an optimal j (20 in this case rather than 13) I come up with a far better lower bound: 1,285,930,588. Not to brag, but this beats Wikipedia's claim by better than 35,000-fold!
I revisited the site named in post 1, and the paper has been revised and is now a proof.
In studying it, I can't find any errors, but that's just one opinion.
I'm curious: how did you come across this paper?
Are there any flaws in this approach?
Iff n ≡0(MOD2) then n will be divided by 2 any number of times until an odd number, m1, is obtained. Iff n ≡19MOD2) let n=m1.
Iff m1≡1(MOD4) then 3m1+1≡0(MOD4). Let 3m1+1=a, then either a/2 ≡2(MOD4) or a/2 ≡0(MOD4). In the latter case, either a/2 ≡2(MOD4) or a/2 ≡0(MOD4) and successive divisions by 2 will yield a number ≡2(MOD4). Another halving will give an answer m2≡1(MOD4), and the process is repeated. Since 3mn+1 is always a multiple of 4, mn+1=(3mn+1)/(4*2r), where r>/=0. Therefore, if mn>1 then mn+1<mn. Then each term is less than the previous, and because no term can be <1, the result must converge to 1.
Iff m1≡3(MOD4) then 3m1+1≡2(MOD4) and a/2 ≡1(MOD4), and from there the argument continues as in the case for m1≡1(MOD4).
In the previous post I forgot to put in the subscripts, which may have caused confusion. I also made a typo with one of the brackets. Here is a better version. I used Gauss's congruences in my attempt.
Iff n ≡0(MOD2) then n will be divided by 2 any number of times until an odd number, m[/1SUB], is obtained. Iff n ≡1(MOD2) let n=m[/1SUB].
Iff m[/1SUB]≡1(MOD4) then 3m[/1SUB]+1≡0(MOD4). Let 3m[/1SUB]+1=a, then either a/2 ≡2(MOD4) or a/2 ≡0(MOD4). In the latter case, either a/2 ≡2(MOD4) or a/2 ≡0(MOD4) and successive divisions by 2 will yield a number ≡2(MOD4). Another halving will give an answer m[/2SUB]≡1(MOD4), and the process is repeated. Since 3m[/nSUB]+1 is always a multiple of 4, m[/n+1SUB]=(3m[/nSUB]+1)/(4*2r), where r>/=0. Therefore, if [/nSUB]>1 then m[n+1/SUB]<m[/nSUB]. Then each term is less than the previous, and because no term can be <1, the result must converge to 1.
Iff m[/1SUB]≡3(MOD4) then 3m[/1SUB]+1≡2(MOD4) and a/2 ≡1(MOD4), and from there the argument continues as in the case for[/1SUB] m≡1(MOD4).
