Why Does Machine 1 Act as a Motor and Machine 2 as a Generator?
The discussion clarifies the operational roles of Machine 1 and Machine 2, where Machine 1 acts as a motor and Machine 2 functions as a generator. Both machines exhibit current leaving the positive terminal, adhering to generator convention, yet they absorb negative real and reactive power. The analysis concludes that once one machine is designated as a generator, the other is treated as a load, which explains their respective functions in the system. Theoretical flexibility allows any generator to operate as a motor and vice versa, but practical applications typically optimize them for specific roles.
  • Understanding of AC power systems
  • Familiarity with real and reactive power concepts
  • Knowledge of electrical machine operation principles
  • Basic grasp of power generation and load dynamics
  • Research the principles of AC power flow analysis
  • Study the characteristics of synchronous and asynchronous machines
  • Learn about power system stability and load flow analysis
  • Explore the implications of power factor correction in electrical systems
Electrical engineers, power system analysts, and students studying electrical machine theory will benefit from this discussion, particularly those interested in the operational dynamics between motors and generators in power systems.
Ian_Brooks
http://img528.imageshack.us/img528/6983/energytut1rc0.jpg
http://img300.imageshack.us/img300/8168/energytut1suppou2.jpg
Now why does machine 1 act as a motor and 2 as a generator?
The above question shows that both have current leaving the positive terminal
- so the generator convention is assumed
but they both absorb negative Real and Reactive power. Then why is either a generator and a motor?
Do we consider the other a load once one is assumed to be a generator? Then what happens when we have multiple generators in a network?
I think you may just be reading too much into the figure.
In the absence of anything else, I would assume that machine 2 ("generator") is being turned by a herd of elephants (grad students?--more plentiful) or a waterfall, or a boiler, something which is putting energy into the system. Machine 1 ("load") then spins because of the current output by Machine 2, using up the energy put into the system.
The current convention just says "measure current going this way", but says nothing about whether or not this is negative (which, in this case, it better be!)--or the complex equivalent of this when dealing with AC stuff.
In theory, any generator can be used as a motor and vice versa. In practice, they're optimized one way or the other.
AHhh
so once we choose one convention (the generator side in this case), we assume the other device - the receiving end of the current ( whether positive or negative ) to be at the load side.
Its makes sense now - as device 1 is considered to be on the generator side, its absorbing real and reactive power and hence is a motor
Then the other device is considered to be on the load side and is delivering Real and reactive power and is hence a generator.
I see now.
Thanks
  • · Replies 17 ·
34K
