Importance of Low Resistance per Unit Length in Electrical Cables
The discussion revolves around the importance of low resistance per unit length in electrical cables used for connecting appliances to the electrical supply. Participants are exploring the implications of resistance on current flow and efficiency in long cables.
  • Participants discuss the relationship between cable resistance and current flow, with some questioning the implications of higher current on safety and efficiency. There are attempts to identify reasons for low resistance, with hints and suggestions being exchanged.
The conversation is ongoing, with participants actively engaging in clarifying concepts and exploring different aspects of the problem. Some have provided hints and references to related concepts like Thevenin equivalence, indicating a productive direction in the discussion.
Participants are navigating assumptions about the role of appliance resistance and the effects of voltage on energy loss, indicating a need for further exploration of these factors in the context of the homework question.
Kushal
Some electrical appliances are used with long cables to connect to them to the electrical supply. State and explain 2 reasons why these cables should have a low resistance per unit length.
well for the long cables, a low resistance per unit length would mean a low resistance for the cable itself. a larger current will flow.
i cannot see any advantage in that. rather the cables will be less safe with a larger current. the power dissipated, I2R, will be larger, hence less efficient.
so i don't know...
well for the long cables, a low resistance per unit length would mean a low resistance for the cable itself. a larger current will flow …
Hi Kushal! :smile:
No … you've completely ignored the resistance of the appliance
it is (mostly) that resistance which determines the current, I.
So the current is more-or-less fixed by the appliance.
So the effect of the resistance of the wire is … ? :smile:
yeah you're right, i completely ignored that. a small current might not be able to operate the appliance.
errmm i still can't find the second reason... a hint would be great...lol
thnks
thnks
It looks like you were on to the second drawback in your first try.
EDIT: Nevermind, got resistance confused with impedance.
Anyway, yes you were close. Think of the Thevenin equivalence circuit.
You guys have completely forgot that the higher the voltage of the current moving through the mains power the less energy that is lost through heat and for that to work the resistance must be low.
9K
10K
