Phantom Power: Understanding It for Your Presentation
  • Thread starter Thread starter chaoseverlasting
    Power Presentation
The discussion revolves around the concept of Phantom Power in the context of microphones, particularly focusing on its function, application, and relevance to presentations about audio equipment. Participants seek to clarify their understanding of Phantom Power and its implications for microphone usage.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant requests help understanding Phantom Power, indicating a need for clarification on its role in microphones.
  • Another participant explains that Phantom Power allows microphones to receive power (typically +48V DC) through the same wires used for the audio signal, which is AC. This enables the use of standard XLR connectors and reduces wiring complexity.
  • It is noted that Phantom Power is primarily relevant for condenser microphones, while dynamic microphones do not require external power.
  • A participant draws a parallel between Phantom Power and "Link Power" or "Power over Ethernet" in data networks, suggesting a broader context of understanding.
  • One participant expresses that existing resources, such as the Wikipedia article, were not helpful in clarifying the concept.
Participants generally agree on the technical aspects of Phantom Power and its application to condenser microphones, but there is no consensus on the clarity of available resources or the overall understanding of the concept.
Some participants mention that existing explanations can be overly complex, indicating a potential gap in clear communication or understanding of the topic.
chaoseverlasting
Im have to give a presentation on microphones soon, and most of the material I am pretty good with, with the exception of Phantom Power. I could work around it if I had to, but it would be better if I understood it. Could someone help out?
Can you provide a pointer or intro to what Phantom Power is in the context of microphones?
Phantom powered microphones use the same wires for power (DC, usually +48V) and the signal going back to the microphone amplifier; this is possible because the signal is AC (from about 20 Hz and upwards) meaning you can quite easily "filter out" the DC-current.
It is basically just a clever way of reducing the number of wires+you can use standard XLR connectors/cables.
edit: Note that this is only relevant for condenser microphones, dynamic microphones do not need to be powered.
Ah, thanks for the clarification. This is called "Link Power" or "Power over Ethernet" in the data networks that I work with. Now I know what it's called in the audio world.
Thank you! I'd already looked at the wikipedia article when I asked this question, but it didnt make much sense to me. The simplest things can sound so complicated sometimes.
10K
  • · Replies 16 ·
  • · Replies 37 ·
  • · Replies 33 ·
