Find the areas of the regions whose boundaries are given
  • Thread starter Thread starter duki
    Areas
The discussion revolves around finding the areas of regions defined by various boundary equations, including polynomial and linear functions. Participants are exploring how to correctly set up integrals to calculate these areas, while addressing issues related to negative area results.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to find areas for three different sets of equations but encounters negative area results, prompting questions about the correctness of their setup. Some participants question the boundaries and the relationships between the curves, while others suggest re-evaluating the order of functions for integration.
duki
I have three questions:
Find the areas of the regions whose boundaries are given.
[tex]y=x^3-3[/tex]
[tex]y=1[/tex]
x=-2, x=2
I got -10.67 but I know this can't be true because you can't have a negative area.
[tex]y^2=x[/tex]
[tex]x+y=2[/tex]
y=1, y=-2
I got -4.5, but again that can't be right because it's negative :(
[tex]y=x^3-2x^2-3x[/tex]
[tex]y=0[/tex]
I got to x=0, x=-1, and x=3 but I don't know where to go from here.
Thanks for any help! :)
Let's just start with the first one. How did you get x=-2, x=2 or was that given? The curves y=x^3-3 and y=1 don't enclose any bounded region.
many apologies... it should have been x^2-3
If you get a negative area then you have the two functions in the wrong order. For x between -2 and 2, the graph of x2- 3 is below the graph of y= 1. You should be integrating [itex]\int [1- (x^2-3)]dx= \int (4- x^2)dx[/itex]. That, integrated between -2 and 2, is positive.
And for the last problem, you would have two different enclosed areas. One would be between -1 and 0 and the other between 0 and 3.
This means you would have to set up 2 different equations and find the sum of the areas.
HINT: The equations are very similar just siwtched in order.
  • · Replies 20 ·
  • · Replies 27 ·
