Draw a circle. Now pick two points (A,B) on the periphery of that
  • Thread starter Thread starter kenewbie
    Circle Points
The problem involves a circle with two points on its periphery forming a diameter and a third point on the circle's edge. The objective is to prove that the angle formed at the third point is a right angle.
  • Participants explore various geometric properties and theorems related to angles inscribed in a circle. Some express uncertainty about the proof, while others suggest using triangle properties and relationships between angles.
Several participants have offered insights and approaches to the problem, including referencing known theorems and discussing angle relationships. There is a mix of exploration and clarification, with no explicit consensus reached on a single method of proof.
Some participants mention unfamiliarity with certain theorems, indicating a potential gap in knowledge that may affect their understanding of the problem.
kenewbie
Draw a circle. Now pick two points (A,B) on the periphery of that circle, so that a line between A and B will have to pass through the center of the circle. The line AB is, in other words, the diameter of the circle.
Now, pick a point C anywhere on the periphery of the circle. Prove that in any such triangle ABC, angle C is 90 degrees.
I have no idea. At first I was even reluctant to agree that C is always 90 degrees, but making random points on a circle seem to confirm this.
The best I can come up with is that if I draw a normal from point C to AB, then that normal will always make 90 degree angles, so both "split-triangles" must be similar and so the original ABC must be similar as well, and contain a 90 degree angle.
I don't think that constitutes a proof.
Put O as the centre of the circle and draw in the line OC. Noting that OC is a radius,as well as OA and OB. Put angle OAC=a and OBC=b. Now just use some simple triangle properties and you should get it.
I think that since OC and AC are both R long, angle ACO must be equal to angle A.
And for the same reason, angle BCO must equal B.
Which means angle C should be A+B.
A+B+C = 180
A+B+(A+B) = 180
2(A+B) = 180
A+B = 90
C = 90
That seems to work. Thanks a lot rock.freak, I don't think I would ever have thought to split the triangle between C and O, since the new ones seem so random :)
k
There is a fairly well know theorem that an angle with vertex lying on a circle has angle equal to 1/2 the arc it subtends. If the two points are ends of a diameter, then the arc is subtends is 1/2 a circle, 180 degrees, so the angle is 90 degrees.
Hi kenewbie and HallsofIvy! :smile:
Yes … the method of proof is exactly the same, plus exterior angle of triangle = sum of the two opposite angles. :wink:
Ivy, ok. I've never learned that, perhaps it comes later.
Now I know why :)
k
  • · Replies 16 ·
