Stereoisomerism in dimethylcyclohexane
  • Thread starter Thread starter GPhab
The discussion revolves around the stereoisomerism of dimethylcyclohexane, focusing on the identification of stereocenters, chirality, and the implications of molecular conformations on symmetry. Participants explore whether specific isomers exhibit enantiomerism and the definitions of achirality in different conformations.
  • Homework-related
  • Post 1 presents a classification of dimethylcyclohexane isomers and requests verification of the claims regarding stereoisomers.
  • Post 2 outlines a method for determining chirality based on the presence of stereocenters and symmetry, asserting that certain isomers are meso and others are chiral.
  • Post 3 questions whether the previous answers considered the chair conformation of dimethylcyclohexane, suggesting that planar assumptions may not affect some conclusions.
  • Post 4 defines achirality in terms of having a plane of symmetry in any conformation and introduces the concept of time average symmetry in cyclohexane chairs.
  • Post 5 proposes a hypothetical scenario assuming dimethylcyclohexane exists solely in the chair conformation, questioning the implications for chirality and achirality.
  • Post 6 reiterates the time average symmetry concept, emphasizing that the rapid flipping between conformations supports the achirality of certain chair forms.
Participants express differing views on the implications of molecular conformations for chirality and achirality, particularly regarding the chair and planar representations of dimethylcyclohexane. No consensus is reached on the definitions and implications of achirality across different conformations.
Participants note the importance of conformational analysis and symmetry in determining chirality, with some emphasizing the role of time average symmetry in cyclohexane chairs. The discussion highlights the complexity of defining achirality based on molecular structure and behavior.
GPhab
1,1-dimethylcyclohexane No stereoisomers
1,2-dimethylcyclohexane (Cis,Trans) Do 1,2- , 1,3- exhibit enantiomerism?
1,3-dimethylcyclohexane (Cis,Trans)
1,4-dimethylcyclohexane (Cis-Achiral,Trans-Achiral)
Please justify your answer.
All the fields were blank. I got some of them. Please verify whether they are correct or not.
Here are the steps to solving these problems:
1) Are there any stereocenters? These are atoms connected to 4 different "things." No stereocenters means the molecule is achiral. This means it has no enantiomer, and it's mirror image is the same molecule. It also means the molecule has a plane of symmetry.
2) Is there just one stereocenter? The molecule must be chiral, ie it does have an enantiomer.
3) Are there multiple stereocenters? This is when you have to look for symmetry. Can you cut the molecule in half, along any plane, and end up with the exact mirror reflection on either side? In this case the molecule is still achiral even though it has stereocenters. These kind of molecules are called "meso"
Now I'll answer your questions:
1) Correct. There are no stereocenters here. There are multiple planes of symmetry.
2)+3) These can be addressed together. Both Cis isomers are meso. They have two stereocenters but also possesses plains of symmetry.
Both Trans isomers are chiral and thus exist as two unique enantiomers. Note that both molecules possesses a special kind of symmetry called rotational symmetry which often fools people into thinking they're achiral. Rotational symmetry means you can spin the molecule around a certain number of degrees and end up with the same molecule. Rotational symmetry does NOT necessarily make a molecule achiral.
4) Correct on both counts. The most obvious reason is they both have planes of symmetry. It may or may not be obvious that they both lack stereocenters too.
Thanks Spirochete. Your explanation was useful.
Did you answer 2),3) while referring to the chair conformer of dimethylcyclohexane. Your answers strongly indicate that you have considered dimethylcyclohexane as a molecule with a planar ring. For 1),4), it doesn't make any difference. We can end up with the right answer even if we take dimethylcyclohexane's ring as a plane.
I believe the definition of achiral is that molecule has a plane of symmetry in any conformation. Although cyclohexane chairs are never flat, that is one possible conformation.
Also achiral cyclohexane chairs spend exactly equal amounts of time in the two conformations. So you can think of them as having time average symmetry. This concept of time average symmetry will be useful later when you learn about NMR (nuclear magnetic resonance imaging).
Assuming dimethylcyclohexane exists always as a chair, what would the answer for 2),3) be?
If you encounter any molecule whose mirror is nothing but the molecule which results after flipping(which you should assume to be an instantaneous process), then treat it as achiral. Though this might not be the actual definition of an achiral molecule, this, most probably, is the answer which was expected.
An achiral chair molecule spends 50% of time in conformation "A" and 50% of the time in exactly opposite conformation "B" so it has time average symmetry. The flip happens almost infinitely fast compared to the time spent in each conformation so you're correct that for most purposes we can assume exactly 50% of the time is spent in each "perfect" chair conformation.
Given this fact, none of my answers have changed.
13K
