Average velocity and average speed problem.
The problem involves calculating average velocity based on two segments of motion: walking and running a total distance of 146.4 m. Participants are exploring how to properly compute average velocity using given speeds and distances.
  • Mixed
  • Participants discuss the formula for average velocity and question how to incorporate multiple velocities and the corresponding times for each segment of the journey.
There is an ongoing exploration of how to correctly calculate average velocity, with some participants suggesting methods and others questioning the validity of those methods. Guidance has been offered regarding the need to consider total time rather than subtracting times.
Participants are working under the constraints of the problem statement and are clarifying assumptions about time and distance in relation to average velocity calculations.
afcwestwarrior
Compute your average velocity in the following 2 cases: (a): You walk 73.2 m at a speed of 1.22 m/s and then run 73.2 m at a speed of 3.005 m/s along a straight line.
this asks for average velocity which equals=change of x/change of t or xfinal-xinitial/tfinal-tinitial
isn't acceleration = change of velocity over/ change of time
so what do i do, because it gives me two velocities
this asks for average velocity which equals=change of x/change of t or xfinal-xinitial/tfinal-tinitialisn't acceleration = change of velocity over/ change of time
How long did it take you to accomplish the circuit? Vavg is defined as what? You know change of x, so ...?
Ok. I'm assuming that you add both of the velocities. 1.22 m/s+ 3.05 m/s=4.27m/s
My total distance was 73.2 m + 73.2 m=146.6 m
4.27m/s / 146.6 m=.0291268759 seconds
I think you've used an invalid approach.
The sum of the velocities divided by the total distance is not equal to the time.
How long does it take to do the first leg - 73.2 m at 1.22 m/s?
It takes 60 seconds.
OK. Now how long for the second leg?
It takes 24 seconds
Knowing total distance and total time now you are in position to calculate avg velocity. This is given by which of the equations you cited in your first post?
ok so it would be 73.2+73.2=146.4
146.4m/60s-24s=4.07m/s
wait a minute would i add the time together
Well I sure would. Not sure why you would subtract time in this case. You want total time.
You did post this didn't you?
...this asks for average velocity which equals=change of x/change of t ...
oh yeah huh.
yes i did
