Solving Tricky Math Problems: Cylinders, Curves and Scooters
  • Thread starter Thread starter myanmar
    Curves Cylinders
The discussion focuses on solving three complex math problems involving cylindrical volume transformations, particle motion along a curve, and relative motion of two scooters. For the cylindrical can, the volume is determined by the formula V = πr²h, where the radius increases at 4 in/min and the height decreases at 10 in/min. The second problem involves finding the point where x and y change at the same rate along the curve y = x², while the third problem calculates the changing distance between two scooters approaching an intersection. Key mathematical concepts such as the chain rule and differentiation are essential for solving these problems.
  • Understanding of calculus, specifically differentiation and the chain rule
  • Familiarity with the volume formula for cylinders: V = πr²h
  • Knowledge of parametric equations and their derivatives
  • Basic principles of relative motion in physics
  • Study the application of the chain rule in related rates problems
  • Explore parametric equations and their derivatives in calculus
  • Learn about the relationship between distance, speed, and time in relative motion scenarios
  • Practice solving problems involving volume changes in geometric shapes
Students and educators in mathematics, particularly those focusing on calculus and physics, as well as anyone interested in solving complex motion-related problems.
myanmar
I'm really having trouble with these three problems. I'd post my attempts but most of it is in graph from.
3. David subjects a cylindrical can to a certain transformation. During this transformation the radius and height vary continuously with time. The radius is increasing at 4 in/min, while the height is decreasing at 10 in/min. Is the volume of the can increasing or decreasing, and at what rate, when the radius is 3 inches and the height is 5 inches?
4. A particle moves along a path described by [tex]y=x^{2}[/tex]. At what point along the curve are [tex]x[/tex] and [tex]y[/tex] changing at the same rate? Find this rate if at that time we have [tex]y = sin^{2} t[/tex] and [tex]x = sin t[/tex]
5. Two straight roads intersect at right angles near the Krupps factory at Baden-Baden. Fabio drives his scooter towards the intersection at a rate of 50 kph. Ilsa drives her scooter on the other road away from the intersection at a speed of 30 kph. When Fabio is 2 kilometers from the intersection and Ilsa is 4 kilometers from the intersection:
(a) How fast is the distance between them changing?
(b) Are Fabio and Ilsa getting closer together or farther apart?
Let's start with 3.
The question talks about cylindrical cans, heights, radii and volumes and all of these quantities change over time...oh my god:smile:
So my first question: Can you write down an equation for the height of the can after t minutes? For the radius of the can after t minutes?
Do you know how the volume of the can is related to the height and the radius and can you thus write down an expression for the volume of the can after t minutes?
You can assume that at the beginning ( that is after 0 minutes ) the height of the can is h0 and the radius is r0 ... what would be the volume of the can before the "transformation" starts?
Be careful how you understand Pere Callahan's suggestion. You don't actually have to write the volume as a function of time. You need to write a formula for the volume and use the chain rule to differentiate both sides with respect to t- which you can do even if there is no t explicitely in the formula.
What you do need to do is show what you have tried!
  • · Replies 23 ·
14K
