What Causes a 1000 Times Weight Increase Without Overcoming Gravity?
The discussion revolves around the comparison of gravitational and electromagnetic forces, particularly focusing on why a 1 kg iron object cannot be lifted by a magnet when a 1 gram object can be. Participants explore the factors influencing these forces and the implications of their differences.
  • One participant notes the inability to lift a 1 kg iron object compared to a 1 gram object, questioning the underlying reasons for this disparity.
  • Another participant suggests that the comparison is flawed due to various factors affecting magnetic field strength, such as material purity and temperature.
  • A different participant points out the mixing of concepts, emphasizing that Newtonian gravity and Coulomb's law are both inverse square laws, but magnetic behavior differs significantly.
  • It is mentioned that the mass difference between the Earth and the iron objects is much greater than a simple factor of billions, complicating the comparison.
  • One participant introduces an analogy involving a charged comb and neutral paper to illustrate how electromagnetic forces operate differently than gravitational forces, particularly regarding charge neutrality.
  • Another participant expresses gratitude for the insights and invites further contributions to the discussion.
Participants do not reach a consensus, as there are multiple competing views regarding the comparison of gravitational and electromagnetic forces and the factors influencing them.
Participants highlight the importance of distance in the comparison of forces and the nuances of charge neutrality in matter, which may affect the applicability of their arguments.
This discussion may be of interest to those exploring the fundamental differences between gravitational and electromagnetic forces, as well as students and enthusiasts in physics seeking to understand these concepts more deeply.
litteraround
not able to pick up a 1 kg iron object off the ground by overcoming the gravitational force between Earth and the object.
Consider this : It can pick up a 1 gram (iron) object easily. Then, the increase (from 1gm to 1 kg) would be by a 1000 times. Clearly that increase cannot account for the factorial difference of billions of times between electromagnetism and gravity. What gives?
I know, I am making a simple mistake in my thinking somewhere but can't really figure it out.
You are misinterpreting the comparison. You can't compare bulk material, because a number of factors can affect the strength of the magnetic field (such as the purity of the material, and the temperature).
What you CAN do is compare the magnetic "force" between two electrons, and then compare the gravitational strength between them at the identical distance.
Zz.
Without realizing it you are mixing a bunch of different topics. First, Newtonian gravity and Coulomb's law are both inverse square laws, but an ideal magnet is http://en.wikipedia.org/wiki/Magnetic_moment#Magnetic_field_produced_by_a_magnetic_moment". Second, the difference in the mass of the Earth and the mass of your chunks of iron is much more than a factor of "billions". Third, you are comparing magnetism at a distance of a few inches to gravity at a distance of thousands of kilometers (assuming an ideal spherical earth).
The first point is probably the most important for your practical experiment. If you placed your 1 gram object at the same distance from the magnet as the far side of your 1 kg object it probably would not lift even the 1 gram object.
http://www.youtube.com/watch?v=lmSyJSSuFpM&feature=related
http://www.youtube.com/watch?v=kHXpZpcMLTA&feature=related
To expand a bit on DaleSpam's and Zz's posts, consider the analogy of picking up a small piece of neutral paper with a charged comb. The charged comb induces a tiny polarization on the neutral paper that allows you to pick it up. You won't be able to pick up a stack of papers because the tiny polarization remains the same.
A key thing is that the piece of paper itself is neutral, and the comb only induces the charge. It is different for objects with net charge. If a comb can pick up a small object with 1 net charge, it can pick up an object 1000 as big with 1000 net charges. For electromagnetism, there are positive and negative charges which cancel each other out to a very high precision (a tiny grain of salt is neutral, even though it has gazillions of charges). For gravity, there is no opposite charge, and so even though it is weak, it builds up over large distance. The neutrality of matter is why even though the electromagnetic force is much stronger than gravity, it tends not to be apparent at large distances.
Thanx guys, I think I am getting it. But, if anyone wants to add something, it'd be great.
  • · Replies 20 ·
10K
  • · Replies 219 ·
17K
  • · Replies 30 ·
