Determining the equation of a curve
  • Thread starter Thread starter Craig is Lege
    Curve
The discussion focuses on determining the equation of a curve traced by a point P (x,y) based on its distances from two fixed points A (-1,1) and B (2,-1). The key conclusion is that the distance from point A to point P must equal three times the distance from point B to point P. Participants suggest using the distance formula to establish the relationship between these distances and derive the equation of the curve.
  • Understanding of the distance formula in a Cartesian coordinate system
  • Familiarity with algebraic manipulation of equations
  • Basic knowledge of conic sections and their properties
  • Ability to translate geometric relationships into mathematical equations
  • Learn how to apply the distance formula in coordinate geometry
  • Explore the derivation of equations for conic sections
  • Study methods for solving quadratic equations
  • Investigate the geometric interpretation of distance relationships in curves
Students studying geometry, mathematics educators, and anyone interested in deriving equations for curves based on distance relationships.
Craig is Lege
A curve is traced by a point P (x,y) which moves such that its distance from the point A (-1,1) is three times its distance from the point B (2,-1). Determine the equation.
used distance formulas to find A is the squareroot of 13 away from B.
how do i find the curve
I would try to translate what the problem says in words into equations.
You're told that the distance from point A to point P is always 3 times the distance from point B to point P.
So it seems to me that the way to proceed is to write down an expression for the distance from A to P and set it equal to the expression for the distance from B to P multiplied by 3.
You should try applying the distance formula for the problem as you described it. That should help you to start.
10K
  • · Replies 23 ·
  • · Replies 20 ·
  • · Replies 26 ·
