Can one be a ratioanlist and an empiricist at the same time?
  • Thread starter Thread starter OrbitalPower
    Time
The discussion centers on the compatibility of rationalism and empiricism in philosophical thought. Participants argue that rather than viewing these two approaches as mutually exclusive, individuals can embody traits of both. The conversation highlights the importance of observable evidence in conjunction with reason, suggesting that a balanced approach enhances understanding. Psychological assessments, such as those identifying INTPs and INTJs as more rationalist, further illustrate the spectrum of thought between these two philosophies.
  • Understanding of rationalism and empiricism in philosophy
  • Familiarity with psychological personality types, specifically INTP and INTJ
  • Knowledge of experimental design and testing methodologies
  • Basic comprehension of philosophical debates and dichotomies
  • Research the philosophical implications of combining rationalism and empiricism
  • Explore psychological assessments related to personality types and their philosophical leanings
  • Study experimental design principles to understand how to refine tests based on observations
  • Investigate historical figures who have successfully integrated rationalist and empiricist approaches
Philosophers, psychology students, educators, and anyone interested in the interplay between rational thought and empirical evidence.
OrbitalPower
An empiricist tends to place an emphasis on observable evidence, a rationalist goes off of reason, but why couldn't you mix and match them.
If you Google them, you see a lot of philosophy pages with things like "Ratioanlism vs. empiricism" and so on.
http://plato.stanford.edu/entries/rationalism-empiricism/
Some psychology tests place you as being more ratioanlist or empiricist, I believe INTPs and INTJs are more rationalist.
But why can't you mix and match? For example, I believe it's extremely important to observe things and then to test them, and then reason from them. The reason helps because there may be tests you could do that are misleading or do not show the whole picture, and thus the test needs to be refined (dropping two items of different weight from a low height and a high height, for example). And, of course, testing might show that your the principles you had originally reasoned on were clearly wrong, as you tried the conditions.
Wouldn't most people really be a mix of the two, rather than an either/or scenario?
Yes, to set these against one another is to create a false dichotomy. They are not mutually exclusive in a healthy, reasoning mind.
Yah. I also think that there may be somethings that begin with ratioanlism, and maybe some of things ratioanlists attribute to being innate could be said to be from experience. So it's more about the degree to which you are either one of them, or rather, which whay you lean on a scale of rationalist or empiricist.
  • · Replies 21 ·
  • · Replies 45 ·
