Trigonometry equation, principal value(i dont get this at all)
  • Thread starter Thread starter joker2413
    Trigonometry
The discussion revolves around solving a trigonometric equation involving cosine, specifically finding the principal values of the variable x. The original poster expresses confusion regarding the steps to solve the equation 3cos x - 1 = 2 and seeks clarification on the process.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss rearranging the equation and question the validity of their steps. Some express uncertainty about the implications of cosine values and the meaning of principal values. Others suggest reviewing definitions and concepts related to trigonometric functions and their applications.
The conversation is ongoing, with participants providing guidance and exploring different interpretations of the problem. There is a mix of attempts to clarify concepts and address misunderstandings, but no consensus has been reached on the correct approach or final answer.
Some participants mention reviewing trigonometry and express uncertainty about specific rules related to cosine functions. There is also a reference to the need for clarity regarding the definitions of sine and cosine in different contexts.
joker2413
1.Solve the following for the principal values of the indicated variable.
2. 3cos x-1=2
3. 3cosx - 1 = 2
3cosx+1=0
im not sure what to do from here, I would ask a teacher or a tutor but it is summer work for a calculus course and i forgot what to do. I have looked in a precalculus book at the library and couldn't understand what i was supposed to do. Please explain how you solve this equation and I will be most grateful.
joker2413 said:
3cosx - 1 = 2
3cosx+1=0
Re-check this.
3cosx-1-2=0 gives what? (does -1-2=+1?)
@_@ lol i must be tired... thanks
3cosX - 1 = 2
3cosX -3 = 0
but i still don't have any idea of what to do from there.
How about instead:
3cos x- 1= 2
3cox x= 3
cos x= ?
HallsofIvy said:
How about instead:
3cos x- 1= 2
3cox x= 3
cos x= ?
that would work to i just wasnt sure if there was any special rules with cos being multiplied..
so the final answer is cos x= 1? or would it be like... cos-1(cosx) = cos-1
X = cos-1
or do i have to do something else?
X = cos-1
cos(x)= 1 you should be able to remember almost without thinking!
But be very careful what you write. To me, cos-1 means cos(-1). I think you mean cos-1(1). What does your calculator say that is?
yeah i did mean X= cos-1(1)
new here and didnt see the tags... sorry...
calc says cos-1(1) = 0 but i kind of remember cos x = 90º
which one is a principal value?
Please, please, please, go back and review trigonometry! "cos x= 90º" doesn't even make sense: you take the cosine OF an angle, an angle is not the value of a cosine!
If you meant "cos(90º)= 0" that is also wrong. Now, exactly what definition of sine and cosine are you using? One problem with the old "trigonometry" definition of "opposite side over hypotenuse" and "near side over hypotenuse" is that your angles must larger than 0º and less than 90º in order to have a triangle: you can't have an angle in a triangle so that cos(x)= 1 because the near side and hypotenuse cannot be of the same length.
But in higher mathematics, we use sine and cosine as functions for many different applications that have nothing to do with triangles or even angles and we want to be able to define sin(x) and cosine(x) for any number x. A good way to do that is to use the unit circle. Draw a unit circle (center at (0,0), radius 1) on an xy- coordinate system. Starting from the point (1, 0), measure distance t counterclockwise around the circumference of the circle. The coordinates of the end point are, by definition, (cos(t), sin(t)). (If t is negative, measure clockwise.) That is, cos(t) and sin(t) are defined as the x and y coordinates of that point.
Notice that if you draw a line from that end point to the origin and also draw a line from that end point perpendicular to the x-axis, you make a right triangle having hypotenuse of length 1 (because the unit circle has radius 1), near side of length x and opposite side of length y so that cosine and sine of that angle are x/1= x and y/1= y.
But also notice that the "t" in cos(t) and sin(t) here is NOT an angle at all. It is a distance around the circle. If we measure the angle in radians, since radian angle measure is defined as the length of the arc subtending the angle defined by the length, with the unit circle the angle measure in radians is exactly the length of the arc that I am calling "t" here. Degree measure is convenient for working specifically with angles and triangles but for any other application of sine and cosine, we always use "radians".
Of course, since a unit circle with have circumference [itex]2\pi r= 2\pi(1)= 2\pi[/itex], we can also see that half a circle, corresponding to 180º, is [itex]\pi[/itex] radians and 1/4 of a circle, corresponding to 90º, is [itex]\pi/2[/itex] radians.
Now, on that unit circle graph you have drawn, mark the points (1, 0), (0, 1), (-1, 0), (0, -1). That should make it very easy to see what values of t give cos(t) and sin(t) equal to 0, 1, or -1.
read what you said a few times but don't get some of it...
but for the problem would it be X = 0 and the principal values are X = [tex]\pi[/tex]/2
and what I am doing right now and for the past 5 days is reviewing trigonometry i just have a little trouble with some of it.
  • · Replies 21 ·
