Charge added between two connected conducting sheets
  • Thread starter Thread starter maxmax1
    Charge Conducting
The discussion focuses on the electrostatic behavior of two large neutral conducting sheets connected by a wire, with a charge +q placed at a distance b from one of the plates. The key equations derived include E=V0-V1/b and E=V2-V0/D-b, leading to the conclusion that V1=V2, indicating equal potential at both plates once charge is induced. This equality is crucial as it prevents continuous current flow between the plates, ensuring a stable electrostatic condition.
  • Understanding of electrostatics and electric fields
  • Familiarity with Gauss's Law
  • Knowledge of voltage and potential difference concepts
  • Basic principles of conducting materials and charge distribution
  • Study Gauss's Law applications in electrostatics
  • Learn about electric field calculations between parallel plates
  • Explore the concept of equipotential surfaces in electrostatics
  • Investigate the behavior of induced charges on conductors
Students and professionals in physics, electrical engineering, and anyone interested in understanding electrostatic principles and charge interactions in conductive materials.
maxmax1
Hi guys,
New here! So bear with me. I know this question has been answered partially before. I have a little confusion however.
Question: two large neutral conducting sheets are connected by a wire and at a distance D from each other. A charge +q is placed a distance b from one of the plates. find the proportion of charge induced on each plate. (hint: model point charge as charge sheet)
Answer:' E=V0-V1/b , E=V2-V0/D-b
where V0,V1,V2=voltage at charge sheet, plate one, and plate two respectively and
E1=field at plate 1, E2 field at plate 2.
V1=V2 therefore: bE1= -(D-b)E2 '
The rest of the question from here uses Gauss and is straight forward. However how is
V1=V2 ? how is potential across the plates to be understood? surely since V=ED the potential will be different at both plates.
many thanks.
maxmax1 said:
Hi guys,
many thanks.
Notice that the solution states that V1=V2 at the plates, however it doesn't say anything about the potential between the plates.
Perhaps the best way to understand why the potential of both plates must be equal, is to consider what would happen if [itex]V_1\neq V_2[/itex].
I see. the voltage must be equal once all charge has been induced, since otherwise, current would continue to flow between plates. As these are negative we can say these are at zero potential wrt the charge sheet?
But the potential between each plate and the charge is different.
  • · Replies 26 ·
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 18 ·
