Question about kinetic friction force?
The discussion centers on the principles of kinetic friction force, specifically addressing two key questions. First, the kinetic friction force (KF) is defined by the equation KF = µN, where µ is the coefficient of kinetic friction and N is the normal force. This force remains constant for a given object on a flat surface, provided the normal force does not change. Second, it is established that when the applied force equals the kinetic friction force, the object maintains a constant velocity, regardless of its speed, as long as the conditions remain consistent.
  • Understanding of kinetic friction force and its formula (KF = µN)
  • Knowledge of normal force and its variations
  • Familiarity with the concept of constant velocity in physics
  • Basic principles of motion on flat surfaces
  • Research the effects of centripetal acceleration on normal force
  • Explore the relationship between speed and the coefficient of kinetic friction
  • Study different materials and their coefficients of kinetic friction
  • Investigate real-world applications of kinetic friction in engineering
Physics students, mechanical engineers, and anyone interested in understanding the dynamics of motion and friction in practical scenarios.
aiklone1314
hello everbody...i got two question about kinetic friction force...
tat is
1. is kinetic friction force of an object always the same value?as the formula kinetic friction force = coefficient of kinetic friction force*normal , coefficient of kinetic friction force is always the same...is me right?
2.then if applied force = kinetic friction force,there is always constant velocity of the object regardless how fast is the velocity ,is it? means that an object with constant velocity,10km/h has the same kinetic friction force with another object with constant velocity,150km/h ?
Thanks for answering me...
Welcome to PF!
Hi aiklone1314! Welcome to PF! :smile:
Yes … KF = µN,
so KF is the same if N is the same. :smile:
But N can be more or less than usual … for example, if the object is sliding down a curve, the centripetal acceleration may make N greater or smaller. :wink:
Yes … on a flat surface, and with no vertical forces, KF (for the same object) does not depend on speed. :smile:
It depends on the two surfaces involved. In many cases the higher the speed, the lower the coefficient of kinetic friction, because the minor collisions between peaks and valleys cause the objects involved to separate slightly at a higher speed differential.
  • · Replies 77 ·
  • · Replies 33 ·
  • · Replies 35 ·
